Question about Dean SM20G2 Deep Fryer
Gas igniter kit
I can't seem to find info on a Dean SM35GM deep fat fryer. It has two outside fryer wells and one center well that is infared heat. It is a gas unit. Can I get an automatic igniter kit for this unit to keep from using the pilot lights continuously?
  • Anonymous Mar 27, 2014
    fryer continues to say heating after being on for long period, and gas kepps going on and off
    Problem Solver:
  • 19 Answers
It could be converted by a qualifed kitchen mechanic. Here is a list of parts for your unit, and supplier.
Posted on Feb 05, 2009
With thermostat off still lets gas thru
Either the thermostat or the gas valve has failed. Locate and disconnect one of the wires going to the thermostat, if unit continues to heat the gas valve has failed, if not, the thermostat is likely stuck closed (on).
Oct 10, 2012 | Frymaster Dean SR42G Deep Fryer
Lights but does not heat
Tallow is animal fat used for cutting threads on pipe work not for cooking mets differant from cooking fat , remove all tallow from unit , could well havd done the thermosat
Jul 03, 2012 | Waring WDF1000 Deep Fryer
What is the reason for the reset button keep poping out on the dean sm35gm
Hi there!
Reset button of hi-limit switch will only pop-out when its sensing bulb sensed temperature higher tha 450F (trip temperature of hi-limit). Theramostat may be bad allowing oil to reach temp above 450F causing hi-limit to trip-off or hi-limit itself is bad tripping-off at temperature lower than 450F.
Check also the position of the sensing bulb of the hi-limit, it may be positioned touching the heat tube (for gas fryer) or heating element (for electric fryer) that's why it prematurely trips-off.
May 11, 2012 | Dean SM20G2 Deep Fryer
Anyone know if covers exist for Dean Frymaster deep-fat fryers? I have three in a mobile unit and want to be able to move the trailer without draining the oil.
Hi there!
For open fryers, oil will still spill even with cover during transit because open fryer cover is not designed to contain/ hold oil inside the fry pot to prevent the spill, it is only designed to prevent foreign objects from falling inside the fry pot when not in use, draining the fry pot before moving the trailer from one location to another is only the best solution.
May 08, 2012 | Frymaster Dean 2424G Deep Fryer
Dean SM35GM pilot light low and burners won't ignite
The first thing that you need to check is the gas regulator in between the incoming gas line & the fryer. There is a plastic plug in the top, if this regulator is covered in grease then the regulator is not being vented and you will never get the burners to fire. Next is the gas valve, close to where the pilot tube comes from the valve you will find a screw about the size of a dime or smaller. WITH THE T-STAT TURNED TO THE OFF POSITION Remove that screw cap & down inside there is a plastic adjustment screw, with the unit pilot on, adjust that screw counterclockwise to the desired flame height. You won't need more than a couple of inches, now cycle the t-stat on and the burners should light. If they do not e-mail me at & I will walk you thru it.
Jul 10, 2009 | Dean SM20G2 Deep Fryer
Dean gas deep fryer m# SR142GN
Thermocouple is getting weak. Replace the thermocouple with a new part.
Apr 21, 2009 | Frymaster Dean 2424G Deep Fryer
Dean SR152GN Fryer
Is the unit propane?If so the baffles may be sooted up and need to be cleaned.This usually causes blowback.
May 19, 2008 | Dean SR14E Deep Fryer
Immersion Element (
This should be the info you need; on the left is the link for the user manual. Hope this helps - please ask again if you are unsure :)
Apr 12, 2007 | Euro-Pro F1063 Deep Fryer
Dean SM20G2 Deep Fryer Logo
195 people viewed this question
Top Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Paul Carew
Are you a Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
