Question about HP iPAQ HX4700 Pocket PC
Do I have to hard reset after pc-break down
I had just upgraded my Ipaq hx4700 with active sync and rom updates, when my stationary pc broke down and I had to reinstall everything again. Do I have to make a hard reset, install and then update again?
    Master:
  • 450 Answers
No!!!! ROM-update currently in ROM !!!!
Posted on Sep 14, 2005
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Hx4700 Dead
Try reflashing the rom:
Aug 17, 2008 | HP iPAQ HX4700 Pocket PC
Not working after rom udate form hp website
There have been many souls with the same problem. You can find the fix here.
Mar 14, 2008 | HP iPAQ HX4700 Pocket PC
Ipaq H4150
Have you used a Vista PC as the host machine? ROM updates can only be done from a Win XP or 2000.
Hook the iPaq to an Win XP or 2k PC, install active sync first, and then get the ROM update again. Run the Rom Update Utility and it will recognise the iPaq and will update it correctly. :)
Dec 10, 2007 | HP iPAQ H4150 Pocket PC
Outlook 2002 Reinstallation
The default e-mail client on pocketPC 2003 is the "inbox" which is merly a utility for retreiving & sending e-mail. There is no "outlook 2002" on pocket PC's. The Outlook 2002 installation cd comes with most iPaqs and is intended for your pc, not your ipaq.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Delete calendar
Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Don't forget to change these settings back.
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
ActiveSync
try soft reset on your Ipaq and a restart of your PC.
HP iPAQ HX4700 Pocket PC Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
