Question about Motorola Mobility RAZR V3
Firmware How do you flash the firmware? And doing so will help a phone that has a locked keypad?
  • 54 Answers
I use different software for the different phone models. If you flash the phone it restores the software to new condition. So yes it will unlock a locked keypad.
Posted on Sep 03, 2008
SOURCE:
My sony w395 has no lock on keys so if its in my pocket and i lean on it it can make calls which im not aware of i need to lock the handset with the slide so it unlocks when i open it thanx
You have to turn on the auto keypad lock.
You can see the steps here.
If its not working then we need to flash the firmware, as its a bug then,
Do tell me if it works or not.
Concerned, Nooh.
Sep 11, 2011 | Cell Phones
I need to unlock my keypad on motorola w385
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose
Sep 21, 2009 | Nokia 3110 Cellular Phone
N95 Display gone when slid down the keypad
you have to go to settings and go to keyguard settings and then disable the automatic key guard
Aug 31, 2009 | Nokia N95 Cellular Phone
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
Trying to lock my phone
I am not aware of a way to do this only how you have already done it.I mean if you locked it, how would you be able to slide the unlock your self? There is no option of a keypad until you get to the main menu screen. This is all I have on passwords, but you have prob already done this.
Q. Can I password lock my phone to make it more secure, & what is the default Password or Pass code?
A. Yes. Main menu => Settings => Security Setup => Phone Lock
Password is defaulted to 1122 (You can change the password from Change password Function)
If 1122 does not work on your phone for some reason, then try 0000 or 1234.
Q. I password locked my phone to make it more secure, now I can't remember the password, what can I do?
A. You can try removing the battery from the phone for 24 hours, then see if the phone resets. If that doesn't
work, & since there is no known hardware reset for doing a factory reset of the firmware, then the only option is to
flash new firmware to the phone, or at least flash over the user data area of the firmware on the phone. Both methods
still require the purchase or making of a special flash cable, the software, & doing the flashing process.
Mar 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Faulty w850i
Are you sure you have flashed it correctly? I had a white screen problem and flashing fixed it. Make sure both your main and fs firmwares are the same type eg W850_R1ED001_FS_VFE_LIVE_1_RED52
W850_R1ED001_MAIN_GENERIC_CY_RED52
and your custom pack can be any w850
Dec 03, 2008 | Sony Ericsson W850i Cellular Phone
Keypad on nokia 6300 has stopped working
hi
this kind of problems occurs when the Phone Software Goes bad try to get that phone to be flashed ista process that repairmans do to give a phone a fresh firmware/Flash File
best regards
plz do rate this post as good as u can!!
Oct 06, 2008 | Nokia 6300 Cellular Phone
Motorola v635 dead
you have a software problem. take your phone for flashing. but if there was water damage, then the phone might be dead.
flashing the phone replaces the phone's firmware with new firmware, making the phone brand new
Jun 13, 2008 | Motorola Mobility V635 Cellular Phone
Keypad dont work
take the phone to a mobile service center and have them correct this issue for you.
Aug 14, 2007 | Motorola Mobility V180 Cellular Phone
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
