Question about Whirlpool Duet GHW9150P Front Load Washer
Water pouring out from the detergent dispenser
I have a Whirlpool; Duet Sport, purchased in 2006. The hose from the detergent dispenser to the machine is backing up almost immediately when the water comes into the dispenser. Any thoughts?
  • 3 more comments
  • mkirkwag Sep 13, 2008
    Samsung 448 - water pouring out the dispenser.
  • erineh24 Jan 03, 2009
    water just pours out fromt he dispenser. the hose doesn't feel clogged but it is very hard to get to.
  • amnelson1975 Jan 03, 2009
    Water pours ourt from under our detergent dispenser too on our Whirlpool Duet Sport WFW8300SW02. We took off the top and the hoses that lead from the detergent dispenser to the laundry basin seem clear to the touch. There are 2 hoses though....is one for the water with detergent and one for the water with bleach/fabric softener? We're not sure. Some of the water does make it to the laundry basin, but the majority pounrs out onto the floor. With the top off, I noticed a lever at the back of the detergent dispenser. Does anyone know what that is for? Could the lever be broken and displacing water? I'm clueless about all of this!!!
  • Anonymous Apr 25, 2009
    WATER POURS OUT FROM THE TOP OFF DETERGENT DISPENSER, ALL OVER THE FLOOR. IT IS A HUGE MESS. BEGINNING TO WISH I NEVER BOUGHT THIS. THE REPAIR FEES ARE ADDING UP.
  • Anonymous Mar 30, 2014
    Whirlpool duet sport water pouring out of detergent loader when the machine is filling up
  • 5,911 Answers
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Posted on Sep 03, 2008
  • Walt Kutney Jan 16, 2011
    After removing the dispenser tray I can see the dispenser base full of water. I squeezed the large drain tube (reaching in above the tub you can feel this tube) and you can see the water level change. I ran hot water into this base (start slow low pressure flow) and kept working this tube and eventually the clog cleared.
Water is pouring out of the soap dispenser onto the floor. how to resolve this problem?
sounds like the dipencer hose came loose.
Unplug & remove screws along top of washer in back.Lift up & remove. You should be able to access issue from there
Mar 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Whirlpool washer overflows at detergent dispenser
Hello, I worked on a problem like this a few days ago. Your problem is going to be a blockage in the inlet to the drum. To fix this problem find the inlet pipe normally located above the door behid a flap of rubber..push your fingers up there to see if you can feel a blockage..If not your going to have to remove the lid of the machine to access the pipe that leads from the detergent drawer to the tub. Look at the rear top of the machine..You will see three screws....remove them and push back and lift the top panel (lid) now you should be able to access the pipe. Pull the pipe off and clean it out, i suspect you will find a sock blocking the pipe :) If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Sep 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Leaks from under detergent dispenser
there is a hose that runs from the soap box to the drum to let the water into the drum if it is not connected or has perrished then that would explain the waterfall
Jun 11, 2009 | Washing Machines
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pouring out of the detergent holder duet sport
you have an article of clothing stuck between the tubs. run your hand around between the tubs and you will probably find something at about the 11:00 o' clock position.
Jan 13, 2009 | Whirlpool WFW8300SW
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Maytag front load washer leaking water from detergent dispenser
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Oct 28, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
796 people viewed this question
Dan Webster
Dan Webster
Sal De
