Question about Insignia Digital-to-Analog Converter for Analog TVs
VCR only records/plays in black and white
After hooking up the Insignia NS-DXA1, i can't get videos to play or record in color...only black and white. I tried adding channel 4 to the list of channels (my old channel for the vcr) but it kept saying No Signal. I can only view videos on the "Component2" channel. anything i'm missing to change this?
Thanks
I just recently purchased an HD Samsung television and am trying to use it with an Insignia theater system, but picture images are night vision in blue and white. What's wrong with picture? My cable company is baffled, to say the least. What is wrong with this picture? If this system is incompatible to current quality HD television systems then it needs to be removed from market or modified.
Posted on Oct 05, 2008
I need help in setting up my VCR player to my DVD recorder
You should be able to connect the video and audio outputs of a VCR (look for a yellow plug labeled VIDEO OUT and a white (or a white and red if it's a stereo VCR) plug labeled AUDIO OUT on your VCR to the same colored jacks on your DVD recorder labeled VIDEO and AUDIO IN. You'll need an RCA patch cable that has yellow, red, and white plugs-they're readily available at just about any store that sells electronics (Walmart, Best Buy, Target, etc.) and should cost less than $10. Don't let them upsell you to the expensive cables-you're probably not going to notice a difference.
Once you're hooked up, just hit "play" on your VCR and "record" on your DVD recorder, and you should be good.
Dec 29, 2012 | Televison & Video
Getting frustrated. Cannot record on VCR with new converter box!!
Click here to find more instructions on how to connect the Insignia Converter Box. Using any of the connections from the link above will only allow you to watch the channel that you're recording from. Make sure the VCR and TV are tune to channel 3 or 4.
Let me know if you require further assistance.
Aug 12, 2009 | Televison & Video
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Stand Alone VCRs do not play pictures on my Insignia 24" TV
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
Apr 04, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
Nov 21, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia Digital-to-Analog Converter for Analog TVs Logo
782 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
