Question about Kenmore 98702 Stacked Washer/Dryer
Rinse cycle problems
Once the machine (not sure the model) gets to the rinse stage, it makes a hum noise and does nothing else. If I turn the knob to the Spin cycle, it again resumes as normal.
    Genius:
  • 1,028 Answers
Ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Posted on Sep 03, 2008
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Will not automatically switch from washing spin to rinse.
check to make sure you have both the hot and cold water lines connected and the water is turned on. sometimes the hot or cold line will clog up and it will not fill up during the rinse cycle. the humming sound may be the water valve coming on but no water is coming thru.
if you have a warm rinse set it to that to see if this is the problem.
you can clean the screens on the water valve by taking the water inlet hoses off the machine and you can look at the screens onside.
if not it may be a timer problem.
Jun 26, 2008 | Roper RAB2121KW Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
238 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
