Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Saeco digital plus. Grinds beans and then does not dispense any coffee. Dumps dry grounds into drawer. Held button to adjust water amount and it worked but then returned to not working again.
  • idipar Sep 10, 2008
    The machine is now 3 years old and since 2-3 months the coffee bones are grinded but the most part of it go down in the "recepctacle". We try to open the filter and it works during one month only
    B. Parreaux
    idipar@cmm.com.py
  • 515 Answers
try to make a cup of water (Tea) and see if you can get a full cup or just a half.
/Mirran
Posted on Sep 03, 2008
Seams that my saeco incanto deluxe has a problem with the brew group possibly the boiler the grounds come out dry. If I do a rinse cycle the water still flows help? How do I clean the boiler?
Hi
Dosage lever or knob (small knob in the bean hopper) is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click back from the full positive, and that should take care of the problem. Another thing that can cause this is the grind is too coarse or the grinder has come apart. The grinds should look like coarse sugar.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping dry grounds.
Aug 19, 2011 | Saeco Incanto Classic Espresso Machine
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Whenever I brew a cup excess water and ground coffee fill the drip tray. What should I do?
HI
Its normal to relieve some water (half to 1 oz.) and coffee, but excess is caused by having the small knob in the bean hopper set to the minus side. Twist the knob towards the plus side but not all the way, as this can cause an over charge and dump dry grounds in the dredge drawer and not make coffee at all. Another cause is your grounds are too coarse. If this is the case, when the grinder is running twist the big knob in the bean hopper to a smaller # but only do 2 #'s at a time and then make at least 4 coffees before making the next change. You can get the grinds too fine and have an other problem.
Oct 27, 2009 | Saeco Incanto Classic Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Good Luck!
Mar 07, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
The water is not adding to the ground beans , is it plugged?
I haven't seen a Vienna in a long time so I cannot remember if there is a door for preground coffee, if that option is there, open door and press button to make a coffee if you get water, then adjust the grind and dosage on the grinder and try the auto function.
Jan 17, 2009 | Saeco Vienna Digital Coffee Maker,...
No water through the dispenser
http://www.starbucks.com/customer/faq_qanda.asp?name=brewequip
try this link if it cant help u fix the problem it can direct u to someone who can
Nov 30, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
254 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
