SOURCE: Hp laptap pioneer CD wont play
I had the same problem. Go to the link below and follow the directions. Don't worry if you don't have a lower limit directory. I didn't and it still worked. Before restarting go to the device manager and uninstall the driver. I have a similar computer to yours and when I restarted it automatically reinstalled the driver.
http://support.packardbell.com/uk/item/index.php?i=topic_02125&ppn=PB42B00901
SOURCE: wadliwy sterownik do pionieer dvdrw dvr- k17b ata
solution is :
Idapsofuiaortji dasjkldjkll; lld, ,xc,cvf99909asdpert
l;dlfg
445l;lflgf lda;s'; '
e=-df--fasdas
SOURCE: Hi my Pioneer DVDRW DR-TD08HB on my Compaq CQ45
Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on the plus signs (+) next to the following folders
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
