Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Focus problem Hi all. I have a Canon 300D Rebel camera and I find there is a major problem with the focusing - most pictures come out too soft whether I'm on Auto or Manual. I've got a job on Monday and intend to use that camera so I wonder if anyone can help get the best out of the focus. Thanks in advance.
    Sergeant:
  • 255 Answers
Suggestion: 1. camera probably has a sharpness setting. 2. avoid wide open, F/5.6 is the sweet spot on most lenses.
Posted on Sep 14, 2005
SOURCE:
EOS Rebel 300 D will not focus
Assuming you have not switched auto focus off on the lens and not been in the camera menus you should try a different lens to eliminate whether it is the body or the lens. Body failure to focus is rare and unlikely, more likely to be the motor in the lens.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Canon Digital Rebel / EOS-300D Digital...
My photos look blurry not focused. Have tried turning off the auto focus and manually focusing. They are always slightly out of focus, why?
check and make sure you do not have the soft focus turned on. that will make the pictures "soft" in focus or seem out of focus.
Feb 03, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon EOS 300D which is over Exposing
try adjusting the exposure levels set default zero to negatives untill your sure of the right exposure that you want....hope this helps
Nov 25, 2009 | Canon Digital Rebel / EOS-300D Digital...
Auto focus is not working properly and will not
You want to charge people for a membership to get answers from your site
but you want me to "tell you how I did it" for free. Hmmmmmm?
Sep 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel xti focus issues
I think it might be a lens issue.
make sure you change the macro option. the macro must be activated if you are taking a picture of something which is close to the camera. if it's not activated, the picture will not be focused.
The same will happen if the item is far and the macro is ON.
Aug 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 300d autofocus problem
Have you choose a correct "Focusing Point" by pressing the right outmost button on the rear of the body, just above the CF card compartment door?
Feb 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel 300D
id recommend taking it to the canon dealers..this seems like a problem with the software
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel focus
I would only suggest you might clean the metal contacts on the inside rim of the lens....just be very careful what you use....a pencil eraser is good but make sure you clean away any shavings that might get into the camera...
Sep 27, 2007 | Canon Digital Rebel / EOS-300D Digital...
My 300D wont lock on a point in its AF setting
If you are unable to focus in broad daylight and it just hunts through the whole focus range without locking, then it sounds like a problem with sub-mirror pin (also called the second mirror pin). My 300D just had this problem and I had to send to service to get fixed. I sent to http://www.keh.com/ as they were at least $50 cheaper than going straight to Canon. Just got it backed and it works like a charm again.
Jul 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
