Question about Dryers
Calypso Dryer thermistor replace
I have a Calypso dryer that displays "error code E1"
I would like to know how to locate this part or where I can find a manual for repair. Thank you.
  • 1 more comment
  • eagles531 Sep 04, 2008
    What do I remove? What is it I am replacing?
  • meisam Feb 25, 2009
    hi
    I have a air dryer(cad 170)from calypso company and I want have some information
    1:maximum and minimum presser and temprate of gas 404a inside the piping in dryer
    2:what is the expantion valve.this valve open in ehich temprator or presser.
    3:what kind of expantion valve we can use instade of this expantion valve
    by thanks
    Meisam nasipour
  • todnic30todd Mar 11, 2009
    My Calypso dryer reports an E1 error code. Do I need to replace the thermistor?
    Genius:
  • 1,028 Answers
If e1 is thermistor code remove bottom panel look behind lint screen housing should be a black oval object with 2 wires just behind housing and to the right of the white thermal fuse
Posted on Sep 03, 2008
  • shetektn Jul 20, 2011
    This is my second thermister for this dryer. We have got to move it so that the exhaust has a more direct outlet. FixYa always has the answer for my DIY fixes and this is certainly a DIY. My Calypso is Model 110.61066000, Type DDOT-ELE-2406028-EL54. Remove the bottom, front panel with a screw driver. I used a flashlight to locate the clips (one on each side) and pull it open from the top of the panel. The thermister is on the right directly behind a "guard" which needs a very small socket or wrench (sorry, don't recall size) to loosen. You can swivel the guard out of the way to pull the thermistor or just remove the guard all together. I removed it because I wanted to be sure I knew what I was touching and connecting. 30-45 minute job and I even vacuumed all the lint out since the panel was open. UNPLUG the dryer and do NOT bend or break the thermister while handling. :)
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Tip
    Whirlpool Calypso Dryer Error Code Explanations And Repair
    Failure - Code Condition - Check/Repair
    PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
    E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
    • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
    Normal thermistor resistance values:
    • 60 degrees F. - 15.3K ohms.
    • 70 degrees F. - 11.9K ohms.
    • 80 degrees F. - 9.2K ohms.
    E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
    • This error code is displayed only in diagnostics mode.
    on Jul 19, 2010 | Washing Machines
    Whirlpool dryer GEW9200LWO shows error code E1. where can I get a manual and repair manual with step-by-step directions so that I can repair it myself?
    Contact the manufacturer for info regarding the error code. Service manuals are available at a price on the web or maybe from whirlpool. A dryer is a relatively simple device. What are the symptoms of the anomaly?
    Jul 12, 2015 | Whirlpool Dryers
    I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
    Hello there and thank you for choosing fixya
    The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
    Dryer thermister - Located on the blower housing next to the thermal fuse.
    Part Number: AP3919451 made by WHIRLPOOL
    HERE IS WHAT IT LOOKS LIKE
    Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
    The dryer keep saying E1
    Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
    Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
    Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
    May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Code E1
    E1 or E2 Thermistor Failure
    Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    My kenmore dryer is blinking e1 can you tell me what the prolbem is.
    I have a Kenmore Electric HE3 dryer that displays the E1 error code. My husband is good at fixing just about anything so he wants to fix this himself. Is this the Thermistor? Where is it located?
    Sep 09, 2009 | Kenmore Elite HE4 Electric Dryer
    My dryer stops in mid cycle and gives me an error code of E1
    It is a bad thermistor on the blower housing
    http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
    Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
    I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
    E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
    You need to call a repair person to fix it.
    Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
    Error Code E1
    Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
    Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Dryers Logo
    694 people viewed this question
    Top Dryers Experts
