SLOW TURN ON
I HAVE A AUDIOVOX FPE3205 TAKE A LONG TIME TO TURN ON ONCE ON WORKS GOOD
DID you find out how to fix it? i have the same problem thanks
Posted on Nov 16, 2009
  • fnbodog Nov 16, 2009
I have an Audiovox FPE3205 that the picture doesn't hold the clarity and gets blurry and grainy. Support said that it needed to be reset, but I've done that and still the same issue
I do not want to type the answer to this problem because I do not like to be the bearer of possible bad news. This television having been manufactured around 2006 may have reached the end of its life. As years go by, the picture quality on all LCD televisions diminishes.
Ok, ok, I got that out of the way first. Now forget that I just said all of that for a moment. This television will display a 720p resolution from its component input (green, blue, red, white, red). Make sure that whatever is connected to that input is only set to display images at a 1080i or 720p resolution. A wii or a regular dvd player not a bluray should look ok on the composite/RCA input. I'm not recommending the S-Video input for anything, and of course a computer can be connected to the VGA input still.
If the television looks bad even when displaying content on that 720p input then service can be considered and boards changed if you want to put money into this television rather than purchasing another one.
Oct 08, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
Audiovox FPE 3205 blue light on but warm-up time now 45 min.
There are some already dead/dying components and/or dry solder. I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
Hello,I have a AUDIOVOX-FPE3205. Red light on front panel flashing didn't count,sisling noise from back. can this be fixed?
It sounds like you may ahve bad power supply, that will be the first thing to look at.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 07, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
No sound
Disconnect any audio / video cables going to your input sources. Then plug only 1 component in and see if it works. Sometimes there is a feature in certain tvs to disable the audio from the TV menu. Use your tv remote to cycle through the menu settings to see if your audio / sound was accidentally disabled. All else fails call Toshiba, they generally will help you for free.
Sep 02, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Hello, I have a Audiovox FPE3205 that the power just cut off and won't come back on. I'm thinking it has a blown fuse but I don't know where to look. Can you help?
There is a fuse on the power board labeled F901( 5 amp) for the AC supply. Therre is also a fuse, F902 (3.15 amp) between the large capacitor and the heat sink, for the DC side.
The power supply for these TVs is weak. Many capacitors fail leading to other parts burning out, like the PWM IC, ICE2A180Z and the current sense resistor R959 (2.2 ohm, 2 watt).
I recommend trying to find a replacement power board.
Monitor Mike
Sep 20, 2009 | Audiovox FPE3205 32 in. HD-Ready LCD...
My Audiovox FPE3205 has a black screen with a flashing picture that flashes just a split second.
there is a problem on your back light inverter transformer.the fusible that supply the backlight is open.i have encountered already for that problem.
Aug 01, 2009 | Audiovox FPE2306 23 in. LCD Television
TV Picture does not come on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
Inputs all red...
The Red light stay on, no green light to see screen.
May 31, 2008 | Audiovox FPE3205 32 in. HD-Ready LCD...
I get no sound when i hook up dvi-d in port on my audiovox tv model # fpe3205
A DVI-D cable is a video only cable does not support audio
Mar 23, 2008 | Televison & Video
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
