Question about HP iPAQ hx2410 Pocket PC
Ipaq hx2410 beem?
Hi, I have this IPAQ hx2410 and I also have a Palm Tungsten E. The palm is able to receive and send beem while. As for the IPAQ, I don't know cause I don't have any program that use the beem (like that remote control program for palm) but I did tried to transfer a contact from my IPAQ to my palm and they don't seem to communicate. Is it that IPAQ and palm can't communicate together or the IPAQ is broken?
    Master:
  • 450 Answers
On your iPAQ, locate a file you wish to beam. Tap and hold the stylus on the file, you should get an option to "Beam File" Make sure your fairly close with other device when beaming files.
Posted on Sep 14, 2005
SOURCE:
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
When i reinstall the Bios on my Ipaq Hx2410 is fail.
I think you've know already (as an experienced technician) that opening h/w case won't solve anything..
The normal BIOS write is about 20 min (or more), longer than that it could be a problem with ActiveSync or your PC connections.
I'm afraid the ROM chip cannot re-restore because flashing basically format and write your BiosRom chip. Just pray that doing "hard reset" will turn your 'tiny' IpaQ to come alive.
Mar 30, 2009 | HP iPAQ hx2410 Pocket PC
How do I make a hard reset on my Palm Zire 31 PDA?
I did not write the posting attributed to me. I have a Palm Tungsten E. My Dad had been using it and I needed to know how to do a hard reset so it would accept my info. I found that on the Palm site after looking on your site. I performed the hard reset and hot synced the Palm with my info.
Thank you, Sue Nutt
Nov 12, 2008 | Computers & Internet
Ipaq hx2410
reinstall windows thats the best i've got...
May 18, 2008 | HP iPAQ hx2410 Pocket PC
There is a reset pin hole on the back of the unit; Hold the power button and push the reset button in the hole with a paperclip. All memory should now be erased.
Mar 26, 2008 | Palm Zire 31 Handheld
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
Hp ipaq rx3715 universal keyboard driver
Get in the PalmOne web site, and ion products support, find and get the driver of the specific model of the universal IR keyboard you are tryng to use with the Pocket PC.
Also, you can google in internet per the specific model of universal keyboard, and you will find several sites with such driver.
Best regards,
Sep 02, 2007 | HP iPAQ RX3715 Pocket PC
Moving data from PALM III to Axim?
There is a program called Peacemaker that will allow you to transfer contacts by IR. I used it to transfer from my Palm III to my IPaq and from my IPaq to my T-68i. It will only allow a block of 50 contacts at a time
Sep 13, 2005 | Dell Axim X5 Pocket PC
Hx2410 general wi-fi questions
Have you been able to connect through your router at home? I'd get that set up and running first. Then doing it on the road will merely be variations on a familiar theme. If you've tried at home but it hasn't worked, let us know something about your home network (what kind of router? using security/encryption?), and about what you've already tried so we can try to help.
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
HP iPAQ hx2410 Pocket PC Logo
109 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
