Question about Mitsubishi WS-55511 55" Rear Projection Television
  • Anonymous Sep 13, 2008
    green flashing. no power
  • 927 Answers
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Posted on Oct 01, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
How do I reset my mitsubishi diamond tv? The green timer light is flashing.... I can't get the tv to come on.
If the light continues to flash with no picture and you still get sound, your bulb is out. Though it could be any number of issues. To reset a Mitsubishi, hold the power button down for approx. 10-15 seconds until you hear a faint click.
Jan 11, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Continuous flashing green "timer" light on front, tv won't reset
Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
Jan 15, 2009 | Televison & Video
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Tv problem
How can this be a generic problem? I had a flashing green light on a Phillips PTV it had a bad solder joint on one of the pins to an optic isolater.
Dec 13, 2007 | Televison & Video
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
