Question about HP iPAQ RZ1715 Pocket PC
Battery is low
If the battery is low, how long would it normally take to recharge using a Car lighter charger?
    Master:
  • 450 Answers
It should take as long as it would if it were plugged into the wall. The power draw should be the same. Although you should make sure your car battery is up to it.
Posted on Sep 14, 2005
SOURCE:
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Battery low signal, then shuts off.
Make sure the car charger and adapter is working (has power), is the Green light on? If not, use a 12 volt test light available from any auto parts store for about $4.00 and check to see that the lighter outlet is hot, the light should light up when you probe the centwer of the lighter socket. If the lighter is ok then replace the car charger for the GPS about $50.00 from Ebay.
Please rate my help for Fixya, it helps to improve my standing on the site. Thanks
Jan 17, 2012 | Garmin Nuvi 760 Car GPS Receiver
Where can i buy one
Hi,the best source for this type of charger pls visit to URL below.
AC/DC Car/Home Multi-Chargers For
SAMSUNG SAC-47 SAC47 SLB-10A SLB10A
The high quality, standard battery charger kit includes a D/C desktop charger with US A/C wall charger, and car charger (cigarette lighter adaptor) for most vehicles. Recharge your digital battery with the desktop charger at home or office or while traveling with the desktop charger and cigarette lighter adaptor.
http://cgi.ebay.com/SLB-10A-Battery-Charger-fr-SAMSUNG-SL820-Digital-Camera-/260776252446?pt=Batteries_Chargers&hash=item3cb779d41e
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jun 29, 2011 | Samsung Digital Camera Battery Charger...
Just got my TTone, confused about when to use the charger
To avoid an eventual loss of power while you are driving and the subsequent unsafe fumbling with the machine, you can plug the TT in the cigarette lighter during your ride. This will supply power to the GPS and recharge the battery.
Alternatively, before going on a trip plug the TT in a USB port of a computer and it will recharge the battery. With a fully charged battery and the car power adapter/battery charger you will not run out of power.
Dec 31, 2009 | Tomtom ONE 130 GPS Receiver
My Garmin Nuvi 255W, which comes on normally when I start the car, is not coming on. It is only about 5 months old. I keep it plugged into the lighter at all times. Do I need to worry about a battery in...
more than that! keeping it plugged into the car is damaging the SIIRF chip and battery when you start the motor. Also the unit needs to be charged properly before use in an AC charger or vIA USB The DC in the car will not fully charge the unit. In fact it also leaks power back to the battery of the car when you turn ignition off, so dropping the volatage and amps of the battery in the GPS.
ALWAYS UNPLUG BEFORE STARTING ENGINE
Always charge/recharge it prior to use in a AC or USB environment
Battery life is average 2 years unless used like you say you have. Then 3-6 months might see it collapse!
try a full and proper recharge first
Please rate our help++++Thanks for using FIXYA
Oct 09, 2009 | GPS
How can I recharge the battery on my Garmin Nuvi?
Just use your USB cable that came with it to connect it to your computer. It will charge just fine. You can also use a cell phone charger that has a USB connector. A lot of cell phones use this type of charger now and the charge will work fine with the GPS>
Apr 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Recharging with out computer
yes there are car chargers for apple check out walmart.com
Feb 26, 2009 | GPX MW3837 MP3 Player
Charging
"unit turns on and off with the ignition switch, sometimes."
There is something wrong with your power cord or the connection to the cigarette lighter. Your unit should turn on and off with the ignition switch. If the unit is on and doesn't turn off with the ignition switch then your unit is running on battery. If your unit doesn't turn on with the ignition switch then the unit is not getting power from the cigarette lighter.
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
HP iPAQ RZ1715 Pocket PC Logo
54 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
