Question about Whirlpool LGR3624JQ Gas Dryer
Whirlpool gas dryer model # lgr7646eq3
Will not spin, where is the belt, i took off the back and top but did not see it and how do i change if this is the problem.
    Problem Solver:
  • 6 Answers
In order to replace the belt on the LGR7646EQ3 dryer you will have to un-latch the top and remove the front panel. First unscrew the two screws under the lint trap. There are two plastic snaps under the front top cover at the front of the dryer. Use a screw driver or putty knife to unlock the snaps. Lift the top cover up but only about four inches. Unhook the front cover from the bottom by lifting it up. Be careful the drum will fall down a bit given the front cover holds it in place. Take the front cover off the dryer. You can now see the belt which rides around the drum and hooks into the tensioner and motor. You can buy a new belt, tensioner and rubber wheels as a kit to replace the old one.
Posted on Feb 18, 2013
    Genius:
  • 1,028 Answers
Put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Posted on Sep 03, 2008
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Whirlpool supreme gas dryer will not heat up. model# LGR7646EQ3
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR7646E Dryer
I have a whirlpool dryer M460-G (SN#MH4612126 ? LGR7646EQ3). The dryer does not heat up. I checked the back and cleaned all the lint. The gas ignites and heats some time but not all the time and when it is...
Replace your gas valve coils!! They will allow the dryer to heat initially, but fail after about the 3rd or 4th iginition sequence.
Part number 279834 and are around $20.
They are located on top of the valve and held on by a steel bracket with two phillips head screws. Plug and play wires you cant mess up.
Fix it up!!
Aug 14, 2010 | Roper REX4634KQ Electric Dryer
I have a Whirlpool dryer Model: lgr7646eq3 serial #:mh4104127 The unit does not generate any heat when under operation. It is a gas dryer and there doesn't appear to be a pilot light. Any recommendations?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
Whirlpool gas dryer, drum doesn't spin
You have a broken or loose drive belt.
You can order a new one online (repairclinic.com) have your make and model numbers handy.
There's also exploded views to help you.
You'll need to remove the front panel and drum front panel, the drum and route the new belt around the tensioner pulley below the drum...
It's a bit tricky but if you take your time you'll be able to do it..
Let us know if you need assistance with disassembly.
K
Oct 17, 2009 | Whirlpool Dryers
Dryer Drum does not spin
SOUNDS LIKE YOU ARE RIGHT. EASIEST WAY TO TELL IS PRY UP THE TOP PANEL. 1ST REMOVE LINT FILTER AND 2 SCREWS BEHIND FILTER ON TOP PANEL.. GET A FLAT BLADE SREWDRIVER AND TOWARD THE FRONT OF THE TOP PANEL THEIR R 2 BLK CLIPS ONE ON EACH SIDE PUSH IN AND THAT SHOULD RELEASE THE CLIPS ONCE YOU GET THE TOP UP. LOOK AT DRIUM IF YOU DONT SEE A BLACK BELT GOING AROUND TUB THEN BELT IS BROKE. PART # 341241 SELLS FR ABOUT 15-28.99. WE STK IT. ITS A VERY COMMON BELT. SHOULD BE ABLE TO GET LOCALLY. IF YOU NEED IT WE HAVE THEM.
allbrandsappliancerepair.com
Sep 16, 2009 | Whirlpool LGR6611L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool dryer
reinstall back.. remove 2 screws under lint screen press 2 clips on front corners with putty knife lift top remove screw on each side top inside front lift front off belt goes over drum ..double it and pass through idler support arm then onto motor pulley ..belt pack may have a diagram
Jul 31, 2008 | Whirlpool Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
677 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
