Question about JVC AV-32D305 32" TV
JVC AV-32D305(?) turns off sound but not picture
Okay, my problem is when I push the power button, the sound and front light goes away but the picture stays. If I have it on everything works normal except there are, what appears to be, interference lines flickering across the screen. Not profound but enough to be annoying. If I push the power button about 7-8 times the picture will finally go off but I can see that the tv is still powered slightly. When I turn it on, I don't get the "shock" sound that it use to do. By the way, we had a lightning storm when this started doing this. Power surge was what happened and the surge protector was fried.
Please help. I love my tv and want to keep it. Please no referrals to a new tv.
Thanks!
  • ps46_4life Sep 03, 2008
    I think I have narrowed it down to a switch transformer, standby transformer, power transformer or maybe a diode allowing a little power to go across. I found a Main board but it is nearly $200, would like to get a $20 part. :)
    Champion:
  • 252 Answers
If you know how to solder ,resolder the amplifier your tv .or check speaker
Posted on Oct 24, 2008
JVC DV3 sound but no picture
hi,
it may video board or video board cable.
good luck
Apr 28, 2010 | JVC AV-32D305 32" TV
BLACK BOX ON LOWER PART OF SCREEN
your closed captioning may be turned on push the cc button on the remote till it says that cc off and that should fix the problem if its not on the remote try the tvs menu.
Aug 16, 2009 | JVC AV-32D305 32" TV
JVC tV D series will not turn on when I hit power
Hi There,
Did you try turning it on from the actual TV power button?
Mar 22, 2009 | JVC AV-32D305 32" TV
JVC av-32fa44 The menu (picture, sound settings, etc)will appear and scroll through all the settings continuosly, and remote cannot close the menu. Power off tv for a minute will clear the problem, but...
Sounds like one of the front panel buttons is jammed. press each one and see if any fail to "rebound" or feel different from the rest. You can usually work the button in a 'circular motion" to release it. If the buttons seem normal , it's possible that the switch inside the TV has collapsed
Mar 10, 2009 | JVC AV-32D305 32" TV
Channel # will not go away. we have dish and have to have the tv set on channel 3 for it to work.
should be able to push display button on remote and it should go away if not have to research this unless some one else knows the answer.
Mar 05, 2009 | JVC AV-32D305 32" TV
Av 32d305 JVC tv
has the problem solved a little yet?
Oct 31, 2008 | JVC AV-32D305 32" TV
AV 32D305
There were no burnt parts but there was 13 extra volts getting by the transformer in a loop causing it to stay on. It was still powering the picture but not the sound. Since I couldn't find the bad part I was just going to replace the whole board for $189., but I decided to get rid of it. I sold it for parts and bought some computer memory so I could watch tv on my computer. :P It was a good compromise, I think.
Oct 22, 2008 | JVC AV-32D305 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Aug 12, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
JVC AV-32D305 32" TV Logo
91 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
