Question about True T-49 Side by Side Refrigerator Commercial
T-49 Freezer Lock
Have been having problems with people not shutting the doors at work and was wondering if it is possible to screw a lock into the door such as a hasp and master lock? Any suggestions? Thank you
  • 943 Answers
Thanks for the question yes on both doors but nowhere else thanks the appliance doc
Posted on Sep 16, 2008
Error code d5
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
the service manual which will tell you how to do some testing of the door lock, but in the end you may need both a control board and a door lock assembly. The good news, they are easy to change out, the bad news, they are expensive parts so you want to be as sure as possible before you buy and install.
Jul 02, 2015 | Maytag Washing Machines
I HAVE A PANASONIC NN-CT776 COMBI MICROWAVE AND THE DOOR REFUSES TO SHUT ANY HELP PLEASE?
Failure of the lock mechanism , fault in the lock switch which cuts off the power to the microwave when the door is opened or a fault in the hinges.
Remove the top cover and look on the sides to the lock section, It is possible that the switch has closed not allowing the door lock to latch. You can use a screw driver to push this and press the door to reset.
Please have the power supply removed.
Jul 23, 2011 | Microwave Ovens
1997 mercury cougar door stuck shut
Hi there I had a similar problem on a 98' ford explorer and replaced the door lock actuator and solved the problem in one shot. If you never worked in cars well it will be a little tricky but if you have little experience well then you have to remove the door panels carefully to avoid damaging any plastic hold screws, once removed try to aceess the door lock from the panel to get it open since it is easier to work. Now with the door open and window up then remove the mounting brackets of the window in order to get to the lock actuator. It is hold by two only one screw just remove the wire hook up and remove actuator. install new one and put everything back good luck..
Sep 05, 2009 | 1997 Mercury Cougar XR7
I have a freezer with a door lock I lost the key
http://www.toysrus.com/product/index.jsp?productId=2748356&fromRegistryNumber=44660901&product_skn=897218
Jun 22, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer door stays open when bottom door is shut
Door or gasket is binding on the upper door or the door is bent. Check and loosen the mounting screws on the hinge. Realign then tighten screws. If you moved the fridge lately the door may have sprung open and is bent. Use duct tape when moving fridges to keep doors shut. The door gaskets may be out of place look on all sides top n bottom for one side making up before the other. A realignment may be all that necessary. Door gaskets warped is sometimes helped by heating it with a hair dryer. if they are coming apart its new gaskets time.
Hope this helps please rate me accordingly even if you just read this. And Good Luck.
Mar 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
I have a new 2007 Roper Refrigerator with a top freezer. The door of the refrigerator does not shut correctly. I can see the light when I look between the freezer door and refrigerator door. If I lift and...
Generally speaking. Refrigerator door are assembled from bottom to top. Remove the cover on the top hinge of the freezer door. Remove the top hinge and lift the door to remove. You will now see the top hinge for the refrigerator door. This should be adjustable by loosening the screws and move it toward the outer edge of the refrigerator side. Tighten the screws and lock it in place. Reassemble the freezer door in the reverse order that you removed it. That should take care of the problem.
You can observe the top edge of the refrigerator door in the closed position when you have the freezer door removed.
Jul 31, 2008 | Roper Refrigerators
Lock on freezer door
Yes, you can put a lock. Visit your nearest locksmith shop and ask them. There are so many varieties of locks. The 4 1/2 keyed Hasp Lock Guard security can be used for this, it can be any other brand. It is a door security lock, the screws are small so nothing will hurt your freezer. Just ask a in a locksmith store. They will know which kind of lock to give you.
Artgirlny
Jul 09, 2008 | Magic Chef 7 cu. ft. / 198 liter Chest...
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Freezer door won't open
There is no lock. More than likely the Door is off track and needs to be reset or ice has set up in the track ceaseing the rails up. In any case this isn't easy you need to get your bottommount freezer door pulled open you may have to use some force and be very careful not to brake it there is alot of plastic. Once you get the door completely out of freezer unclip the rails from the plastice rails and reset the two gears (evenly) to make door shut right. Push metal rails all the way back to you hear a click. Then reverse steps to install freezer door.
Dec 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
True T-49 Side by Side Refrigerator Commercial Logo
49 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
