Question about Kodak Office Equipment & Supplies
Printer will not print anything, has been working very good up to this point.
  • 21 Answers
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Posted on Sep 03, 2008
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Oct 14, 2011 | Dell 1710 Laser Printer
Tip
Installing a printer on the F8T030 Bluetooth AP in Vista
This worked for me...
Install Printer Driver on PC
Select driver properties - then PORTS tab
Add Port
Select "Standard TCP/IP Port" then "New Port"
Next on Wizard
Enter IP address of AP (ensure you have a fixed IP address)
Port name can be anything unique (I used "Belkin_USB2")
NEXT
Wizard will search but not find anything.
Under Device Type select Custom and "Settings")
Set Protocol to LPR
Set Queue Name to "upper" or "lower" depending which USB socket you have used on the AP
Ensure "LPR Byte Counting" is enabled - this is important.
OK
NEXT then FINISH and Close "Printer Ports" dialogue.
Apply settings and try test print.
Worked ok for me (Vista Ultimate 64)
on Oct 15, 2008 | Belkin F8T030 Bluetooth Access Point w/...
My HP D1520 printer does not print anything when I tell it to. The Cartridge is new and I just bought the printer this week. It printed the first few times but no longer does. What to do?
Good day sir, at this point your only choice is to bring it back to the dealer, demand for a refund, if they ask why, demo your printer to them. Let them solve it for you.
Note: chances are that your printer is not properly setup. so watch them dealers test your printer.
Oct 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer wont work
CARTRIDGE OUT OVERRIDE
From the main menu on the printer, press "right arrow" to "System Setup", then press "Select" (green button with check mark)
Press "right arrow" to "Print Quality" and press "Select"
Press "right arrow" to "Replace Supplies" and press "Select"
Press "right arrow" to "Override Out" and press "Select"
Press "Select"
If "stop at out" is selected, the printer will stop printing when a cartridge reaches the recommended replacement point. If "Override Out" is selected, the printer will continue printing when a cartridge reaches the recommended replacement point. The factory default settig is "Stop at out".
Apr 30, 2009 | Office Equipment & Supplies
My windows 7 won't send anything to my dell 810 printer to be printed. The scanner part of it works but that's it. Why won't it send anything to be printed???
Uninstall the Windows 7 drivers, disconnect the printer, download and install the drivers from Dell's support site and reconnect the printer.
Apr 16, 2009 | Office Equipment & Supplies
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | HP Deskjet D4260 Printer
Quattro Pro X3 Refuses to print in anything by Best Quality mode
document contains some control characters that prevent you doing so
Mar 23, 2017 | Computers & Internet
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
