SOURCE: power supply
This unit takes a 12V 0.5A DC power supply. Your local Radio Shack sells this type of supply that will plug into the wall. You'll need to make sure that the other end will plug into the turntable, but for the supply, Radio Shack is probably the quickest way.
SOURCE: Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
SOURCE: Philco 841.205 Turntable Issues
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
