Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Direct TV Hookup
My cat walked on my RCA remote and changed settings. I have Direct TV and my screen only flashes Unusable Signal. I know a setting was changed - my Direct TV works upstairs. What are the settings to use for my remote so I can get a picture? Antenna/Cable, Input 1, 2, 3, 4? HDMI or Front? I believe it used to be Input 4. It just won't work now. Think you can help?
Please help my remote has change language and jumping chanel and pause on mute
Posted on Sep 06, 2008
My rca tv has unusable signal onit
Hi, Check the cable connections to and from the TV.
Change the channels to see if there are others that are out.
If you are not using any cable company then you will still need a set top box to unscramble the digital signal. Good luck.
Jun 06, 2012 | Televison & Video
My RCA L32HD41TV will not work with HDMI cable. What's the problem?
If the set is used on a specific channel on the set--no signal means either a tuner or hookup problem.
If Direct tv has rear audio video outputs connect it that way.
Not clear here how or where you are connected with the box.
Apr 15, 2012 | RCA L32HD41 LCD TV
Keep getting no signal on 32 in lg
Start at the beginning:
Hook a DVD to one of the rear sets of audio/video jacks--go to that input and verify it works.
If so, hook the direct TV to another rear input and select that---if no picture that way---the box may be the issue or wrong hookup--composite to composite or component to component (most likely).
If the set works with DVD and not DIRECT TV it is not smart enough to know what is hooked to it.
In that case a setting or the connection out from the box is the problem---check on screen menu for the box in setup.
Box may need to be rebooted with it connected to set or wrong hookup of cables.
Mar 31, 2012 | Televison & Video
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
When we turn the TV on after hooking up to cable we receive this message on the screen - UNUSABLE SIGNAL
goto main menu , goto setup , goto autoprogram and press start ,
the cable line must be going in to
ant in on the back of the set
and make sure that the video 1 or 2 is off
on the tv
Jun 28, 2009 | RCA F32650 32" TV
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
