-   Wick is only wet where it is in the water.
-   Guest
Jan 02, 2009
-   i have same problem ,the filter is almost new, fan runs, no moisture-   Guest
Dec 15, 2008
-   Also, my unit is not collecting water to humidifer the air. The motor is running I'm going to try to clean the contacts with a soft cloth. What about using a "limeaway" product...-   keslie
Sep 09, 2008
-   The humidifier is running as usual, but there is no water collected,
I haven't any condensation.
To both, these sound like de-humidifiers. Is your goal to reduce humidity and dry your room? If so, if the humidity is low, then the de-humidifier has no work to do. A cheap battery or dial humidistat will help. If not, check for a clogged filter. No air moving spells no de-humidification. Also check for a frozen evaporator coil. Same as above but this requires repairs. Electric dehumidifiers are similar to refrigerators and window AC's. With the fan running, adjust the setting to a lower humidity setting until you hear the compressor kick in. If it does not even at the lowest setting, check the space relative humidity to make sure it has work to do. If it does, repairs may be as simple as cleaning electric contacts in controls or as bad as a refrigerant leak or compressor failure. If its bad, better to replace. A humidifier adds moisture. If you have a humidifier and want to keep the static off your clothes and keep your nose from drying out, fill the tanks with water and add biocide. Please do not view my comments as patronizing. Even seasoned engineers have difficulty grasping humidification.
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find...
(More)
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find one?
Karen Pankratz
pankjp@comcast.net
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of...
(More)
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of replacing hard to find filters of my Holmes humidifier.
Thanks.
Honeywell humidifier HE220. Water is'nt flowing through the solenoid. There is strong water up to...
(More)
Honeywell humidifier HE220. Water is'nt flowing through the solenoid. There is strong water up to the solenoid. A trickle out the rubber tubing coming from the solenoid. Doesn't flow through filter. Have checked wiring and cleaned solenoid filter.
