Question about APC Smart 3000VA (sua3000r2x145) UPS System
APC Smart UPS 3000VA - Dead UPS When I plug in the unit nothing happens no lights, no noise - nothing! Is there a replaceable fuse in these units? Cheers
  • paulleeber Nov 10, 2008
    power to the unit but no fans on lights vo vothin
    New Friend:
  • 37 Answers
Ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
Posted on Mar 28, 2009
APC Smart UPS 3000VA control panel cable short
Do you mean short circuit or that it is too short ??
Jan 12, 2015 | APC Smart-UPS RT 3000VA UPS System
Hi my APC smart 3000 UPS THE AVR boost LED IN ALWAYS ON. DO I NEED TO CHANGE THE BATTERY?
How many years the batteries working?
Usually every 4 years change the batteries.
Do you have power down often?
Feb 24, 2014 | APC Smart-UPS RT 3000VA UPS System
APC SURTD3000XLI UPS error light, 2 battery lights no output
check the fan in the back .... try to replace if damaged
Nov 13, 2013 | APC Smart-UPS RT 3000VA UPS System
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
Dec 15, 2012 | APC Smart-UPS 3000VA USB & Serial...
APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
Hi my APC 1500VA smart UPS show overload without any load in battery mode, but when switched on AC power all lights are blinking. plz describe me how to resolve this Issue?
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
May 06, 2010 | APC Smart-UPS 1500VA Shipboard...
Continous beeping and no led's are lit
Basically for SURT models it should have an internal fault if you get that kind of symptoms. One (1) diode is already opened which is always a problem of this APC SURT series. you need to open the unit and do further troubleshooting or send it to APC service center in you area or APC service partner. if it still under warranty you can call APC call center and get a replacement unit. you just need the exact model and Serial number of the unit.
Aug 07, 2009 | APC Smart-UPS RT 3000VA UPS System
APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot? No power, no lights, nothing and I've never tried to troubleshoot a UPS before. Where do I start?? :-( Thanks Chris
Hello Chris,
I have a similar unit and there is a fuse inside that can blow. Mine did. It worked again after replacing the fuse.
Another option...check the battery connections.
Another option...are the batteries getting old? If so, when they won't reach a certain level of charge the unit will not power on.
Finally, make sure you don't have a blow fuse or popped circuit braker in your home.
Hope this helps?
Charlie
Nov 21, 2007 | APC Smart-UPS 1000VA UPS System
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
APC Smart 3000VA (sua3000r2x145) UPS System Logo
1,217 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
