Question about Frigidaire ATF6000ES Front Load Washer
Drum Speed - Unstable
The drum turns but will not reach high speed because it is banging around. Loud knocking.
  • sintak99 Sep 14, 2008
    My washer spins but makes a very loud thumping noise at high speed final rinse only
  • 30 Answers
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Posted on Sep 03, 2008
  • Bob Johnson
    Bob Johnson Jan 10, 2015
    How is spin bearing repaired?
My speed queen wash properly it drain properly but when it come to spin it go very very slow and it make like jurking movements
Some times the clothing will be piled up mostly at one side of the drum after the completion of the washing/draining cycle. This is normal. When the drum starts spinning/rotating to dry the clothing it is unbalanced and the drum will then not reach high speed due its banging against the outer casing which will also cause the jurking movement. Rearrange the clothing inside the drum by spreading it evenly around the agitator. If this does not solve the problem the machine might be seriously overloaded ( too much clothing). Take some clothing out and see if its is better. If it still persist then open up the front panel by unscrewing the three screws at the bottom of the panel and lifting the panel up and out. Please disconnect the electrical power supply first. Look inside the machine for the van belt between the electric motor and the big pulley underneath the drum. Check the condition of this belt as it might need to be replaced. ( badly worn over all, inner rubber area cracked badly, rough sides ect). TAKE NOTE: Replace with genuine Speed Queen part as a normal vehicle v-belt will not work. Pressing against the belt will be a small pulley attached to a swing arm under tension of a spring. Slight shortening of the spring might help but only as last resort.
Aug 12, 2014 | Speed Queen Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Drum is making a loud banging noise during spin, it is brand new
Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
Sep 08, 2011 | Washing Machines
F 02 code. washer won't drain properly
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drum has come loose
The drum must reach full speed when spinning, otherwise it bangs about everywhere, centrifugal force keeps it up-right like a gyro, the machine is not getting upto speed, try replacing the drive belt.
tilt the machine backwards for access to the belt below the machine, simply pull off and replace wih new by easing the new belt onto the pulleys.
Jun 23, 2008 | Admiral AW22 Top Load Washer
Vibrition at high speed
investigated further by myself couldnt wait
May 25, 2008 | Zanussi FJS1225W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
416 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
