Question about GE Refrigerators
Hi, I have a GE refrigeretor model #ge pds22mbsww the freezer works perfect but the refrigeretor stop working for a day and start to work for about 10-14 hours and then stop agin what to do.
  • 725 Answers
Sounds like a defrost problem or a plugged drain... to get it to work temporary ..defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
( in the GE refrigerator the heater anf the thermostat are sold together)
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Sep 03, 2008
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
Tip
Freezer won't Defrost - GE
This is a Common Problem specially in GE Refrigerators. There are lot of Complaints that, the Refrigerator Section is Working Perfect and it is ONLY the Freezer that won't Defrost.
We have Checked Defrost Heater and Thermostat and still Problem remains the same.On Old Models, you would Find Defrost Timer and in newer Models, Defrost Cycle is Controlled by Motherboard.
Bingo!! you are Correct. The motherboard is again a major Problem and there had many Recalls regarding the same in the past. I would advise you to Check Directly with GE regarding Recall for motherboard.
The other Symptoms of Motherboard Failure Could be :-
1. Dispenser Board Failure
2. Evaporator Fan Motor Failure.
Keep a check on it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
on Feb 19, 2010 | Refrigerators
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
Ge refrigeretor bottom freezer not working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | GE Refrigerators
The freezer and the refrigeretor side are not cold the fan in the freezer is turning
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
GE fridge PDS22MBSWW - relay clicks on and off
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
Sep 21, 2009 | GE Profile PDS22MBSWW
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Frig working, freezer stops working, then starts working again
The computer control circuit board was found to have a burned out circuit. The board is on the lower back side behind a panel, easy to replace. Just need the proper model number to order the board.
Sep 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
