Question about Brother MFC8440 Remanufactured Laser Flatbed Multi-Function Center (MFC 8440, MFC-8440, MFC8440RF, M... Printer
Brother mfc 8440
The error message "check original" comes up on the LCD when i try to copy or fax using the ADF.
  • robbsey May 17, 2009
    Both of my BROTHER MFC 8440 printers have the same problem at the same time - the left hing is broken. Please advise and thanks for your assistance.
    robertaresco@yahoo.com
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Posted on Jan 15, 2009
I have a brother fax machine mfc8220, its displaying in red with error message remove original and the press stop. no paper jam or any paper inside.
Dear Miro
Pl. check the ADF section any of the sensor may clogged.
At least two sensors are there.
thanks.
Feb 26, 2015 | Brother MFC-8220 Fax
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 Check Originals
Check original normally means that there isn't an original in to copy. If it says that when there is an original it probably means that the paper sensor is jammed in some way.
Jun 26, 2009 | Brother MFC 8440 All-In-One Laser Printer
Machine error 6F on a brother mfc-8440
first what is the message???? i will try and help you whenn you let me know the problem or the error message
Dec 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
Brother mfc-8440 printer/fax
you need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Nov 13, 2008 | Brother MFC-8440 All-In-One Laser Printer
Can't make a copy
1: power off and power back on. 2: see the original manual for resetting to factory defaults.
May 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC8440 Remanufactured Laser Flatbed Multi-Function Center (MFC 8440, MFC-8440, MFC8440RF, M... Printer Logo
483 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
