Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Whirlpool 24 in. du1055xtps3
Green light on under lock and dishwasher will not go on
  • 55now Sep 03, 2008
    green light on under lock and dishwasher will not go on
2 Suggested Answers
  • 50 Answers
SOURCE: dishwasher will not start
You have a clean light flashing. You need to reset you control. It is activated by a number of different situations. Find the tech sheet for your dishwasher which is normally located under the bottom plate of the dishwasher. If you can not find it give me the model number and I will tell you how to activate the diagnostic test. If you do find it follow the section that says diagnostic test. Then check and makes sure you heater element is operating.
Posted on Feb 26, 2009
Won't start, green flashing light next to start button. Tightened door screws last week. How do I fix this
? 4:17
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
Oct 19, 2015 | KitchenAid 24 in. KUDP02CR Built-in...
The green light says hold to lock. does not go out. can help turn off plz
Hi friend, thank you for your post!
I understand that the green light for your lock on your Frigidaire dishwasher is not turning off. I see your question is labeled under the model number GSB5712BC based off the design of that control panel you should be able to hold down the power dry button and the lock light should turn off.
If that does not correct the issue I would perform a reset on your dishwasher. You can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
Sep 29, 2014 | Frigidaire 24 in. GSB5712BC Gallery...
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Lock light is on will not go off. nothing will work
Hold the Air Dry button until the light goes off. or Press and hold the "Heated Dry" button for approximately 4 seconds. The control lock indicator light under the padlock symbol will turn off when the controls are unlocked.But if that is not helping then its faulty control panel.It has to be replaced.Unplug the unit from power outlet for 10 minutes then reconnect and check,if lock light turns off.----------------- Thank you.
Jan 24, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Blinking Green Light
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
I have a whirlpool adp951 with a green light flashing
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
There is a green light on with padlock next to it
Try holding the "heated dry" button for 3-4 seconds. It may be that the "child-proof" lock is on.
Nov 28, 2007 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Jun 11, 2007 | Whirlpool 24 in. GU2548XTP Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
88 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
