Question about Mitsubishi WS-65809 65" Rear Projection Television
Taking it apart to move it
I am giving it to my sister and i need to move it to her house. I think it breaks down into two parts. I want to know how to break it down.
  • bjstipes Jan 03, 2009
    How does a Mitsubishi ws-65809 come apart for easy moving?
  • bjstipes May 11, 2010
    Your kidding?
  • 67 Answers
GO TO SHOP
Posted on Jan 07, 2009
There are 2 allen screws on the lower half each side of the set, (they are covered by caps that need to be popped out). Take those screwws out of each side.You will then need to take the speaker cover off and then remove the 5 screws or so that are holding the bottom of the screen to the bottom case. The bottom part of the screen is held on by brackets. Simply lift the screen off after removing the bottom screws. At this point you may want to use a screwdriver and gently pry the bottom case from the top case. They will be difficult to seperate if you don't do this. Once you achieved this, it will take at least 2 people to lift of the top compartment from the bottom compartment. Lift straight up, not side ways as there are to dowel rods that can't be broken. Once you have it apart it will be much easier to move. Obviously, before doing any of this make sure the tv is unplugged as well as dettached from any other components. Hope this helps.
    Genius:
  • 1,027 Answers
DON'T.
Posted on Sep 03, 2008
How to disassemble gear housing of skil 3410 table saw
I don't know. Mostly such things are intuitive when somebody who is used to taking things apart just looks at them and handles them. Sometimes an ally housing needs a little heat to expand it in order to help ease things apart or remove a shaft complete with a bearing. Armatures are delicate and expensive but often some force is needed to remove them.
If you do an internet search for spare parts you will probably find an exploded diagram of your saw which might help.
Feb 25, 2017 | Skil Saws
Im trying to get broken bolts out of t-stat housing that broke while taking apart
Drill a hole down the center of the bolt and use a bolt extractor
Nov 14, 2017 | 2002 Chrysler PT Cruiser
Pick motor seems to be, well, not picking. It is the little arm that drops down to pick up a piece of paper from the paper tray. Making an awful sound.
sorry to hear, well no real quick fix, some things you might check, take off duplexor, check gears on left side, the ones near the capping station, check for paper in gears, if there is remove, now there maybe more paper, just not able to see, so it will require some dissasembly, this is the fun part, well it is for me, i like taking things apart. now if machine is already pulled apart, you will also need to check that the cleaning station is working well, since it is also driven by the same drive assembly that drives the platen. i have taken the platen assembly out, and feed section with it, I DO NOT RECOMMEND IT. putting this part back in machine without breaking or taking aprt without breaking. i would leave alone.. thats all i can give you.
Sep 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
Drivers window won't role up or down
I think I know what your problem is.... It sounds like you need a motor/regulator assembly. There's a cable that attaches the motor to the regulator (part that moves the window up and down ) power is transferred this way. over time the cable breaks allowing the glass to fall to the bottom sometimes and won't go up. electrically it's ok because you can hear the motor run. (good job on the description by the way :) ) you will need to replace the regulator.
If you are technical inclined, you can replace it yourself if you like. most of the work is taking the door panel off. With this kind of stuff I recommend that you don't attempt this one unless you've taking a door panel off before. If you decide to do it, invest in service manual to assist your work. It can be fairly difficult of you've never done one before.
Nov 13, 2008 | 2001 Acura 3.2TL
IBM Acer laptop
Sounds like your power plug has come desoldered. This is internal and will have to be taken apart to repair. If you are comfortable with taking it apart you can repair it yourself. If you have not ever soldered anything before or taken a laptop apart before you need to have someone else do it.
If you decide to do it yourself you will need the instruction manual to locate all of the screws. You will need a soldering iron and a camera along with a pencil and paper to draw a diagram and take notes. Laptops have a lot of fragile parts in them that will break. Do not do this if you do not know how. This is something that a qualified tech should do. You will see the plug and you will need to re-solder it back onto the board. One wrong move and you could damage the entire computer. If you try to do this yourself you are on your own and I am not responsible nor is anyone else.
Most of them have a break down on how to take it apart. The best thing that I can tell you is below. The only thing to do if you do not have the manual is to find a screw and take them out one by one. There should be a way to pop off the top part above the motherboard. You pry on both sides and it should pop up to get under it. The keyboard should pop up from the bottom. All laptops are not the same. Just be very careful, but if you are not sure that you can do it leave it alone. I could do it because I have done it before. Step by step directions without being there is very hard to do.
Jun 05, 2008 | Acer Aspire 3680 Laptop
My hoover windtunnel u6323-930 has dust leaking into air when unit is on. i think it is in the housing I cannot see and I need ti know how to take apart to determine which part i need to order thanks ...
You will just have to start taking the base aprt until you can get the motor, Just remember how it was so you can put it back together correctly again. When you have the motor off, look at the fan chamber, you probably have a crack or hole in it. You can replace the part if it is bad #38736019.
May 31, 2008 | Hoover Vacuums
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
Connecting the pieces
The back goes totally upside down while the seat part is normal and it should slip right in.
Jun 07, 2007 | Graco TurboBooster 8498
Taking apart and moving a 55 inch projection TV
hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Mar 20, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
306 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
