Question about HP iPAQ H5555 Pocket PC
Not starting IPQA 5555 is not starting with Battery. When I put it in crdle then it is working fine but as soon as I remove it from cradle then looks like it is powering off. I also check the Battry. The battery is fully charged. Can you please help in troubleshoot for the above?
    Problem Solver:
  • 5 Answers
Dear  Adib, Before han ding over the unit to repairshop, just try with another battery of the same model as yours (if you know someone who has one). This will ensure that real problem lies for sure with either a battery / or a hardware. Many a times an expiring battery behaves in erraneous way where it shows fully charged within few minutes and goes kaput the moment you connect to the hardware or the hardware is switched on.
Posted on Mar 23, 2009
  • 624 Answers
It may say it is fully charged but I?ll bet that?s not the case. I?ve only had one of my iPAQs die of a battery that won?t hold a charge and what you describe is exactly what it wound up doing, eventually. The batteries aren?t too expensive and if you have the skills and patience you can replace it yourself. Here is a link to a site that sells the replacement batteries and the instructions how to do it: http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=BATT&Affiliate=google
Posted on Jul 20, 2007
SOURCE:
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
My Motorola MC9590-K keeps telling me the USB device is not recognized when I connect with the cradle. The unit does it even when I use a different cradle.
Is it the right cradle to connect. Sometimes the cradles look alike but actually are different. You can check the back and the bottom and see whether all the ports are the same between those cradles. Replace the battery and see if you suspect that is a battery issue. Some of those batteries are not really endurable.
Sep 10, 2012 | Motorola MC9500-K Handheld Mobile Computer...
Power freakout
Sounds like the battery won't pass a battery test, but if it does your explaining dirty battery cable connections clean and or replace as needed as this is the number one reason for a no start . This corrected and known good battery and it still acts up follow the negitive cabe from the battery and disconnect it and clean and reconnect it everywhere it goes. Don't look at it do it. It can look good and be bad. Still bad? the positive cable right at the battery is the root of all evil and you may want too fix it first as soon as the neg cable is removed. Follow the wire and clean everything.
Aug 11, 2009 | 1999 Subaru Forester
Print cartridge cradle is stuck error message
The cartridges & container must be removed and reinstalled.
Apr 03, 2009 | HP PhotoSmart 7760 InkJet Printer
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Exlim z750 not working at all after putting it on charger
I would say the first thing to check would be the charger. If no lights came on it that would be my guess.
Jun 09, 2008 | Casio Exilim EX-Z750 Digital Camera
Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Jan 18, 2008 | Mitac Mio 168 Pocket PC
Error message
This original question is so old it probably won?t help the original poster but instead is meant for anyone who runs across this in the future with a similar problem. If you haven?t already done so backup your data, remove any extra cards or plug-ins and do a cold-boot. If that doesn?t work the next step is to remove Active Sync and install the latest version from Microsoft. If that doesn?t help then the next thing I would try is syncing to another PC and then another cradle if possible. If the problem persists the only thing left to try would be reflasing the ROM.
Sep 11, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5555 Pocket PC Logo
199 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
