Question about RCA F27242GY 27" TV
TV won't turn on
I hear a clicking sound like it is going to turn on but doesn't.
  • 41 Answers
There is a problem with the power supply..the regulator...change the regulator...
Posted on Sep 03, 2008
My 2000 Pontiac Montana won't start. I hear a clicking noise from the back but the starter doesn't engage
have somebody hit the starter with a hammer while somebody turns the key on the start position as he holds the key keep hitting the starter not at the solenoid at the round part if it tries to start then you have a defective starter now if you have a alarm system you are going to have tutoo isolate the starter to do a different test.
Apr 16, 2013 | Cars & Trucks
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
Won't start
Switch on head lights or cabin light. If they doesn't come on or is weak, the battery is flat. Ensure that you switch off the lights.
With ignition switched on, assuming the lights on the instrument panel cames on and your immobiliser is deactivated, turn ignition to start. You should hear the solenoid at the starter making a click sound. If not, the battery is flat or the starter solenoid is faulty. If it does make a click sound, the battery could be too low to turn the starter or the starter is faulty. Assuming the immobiliser is working correctly, and the starter tries to turn the engine but it doesn't want to turn, the gasket could be blown and the cylinder filled with water, or the engine could be seized.
Hope it is not the last case. MarioCpt
Mar 06, 2012 | 1999 Toyota Corolla
Rear winshield wipers won't work
Sounds like you have a stripped arm or the linkage has came apart in the rear for the rear wiper.
The sunroof? I am not sure. check fuses.
Dec 28, 2011 | 2006 Land Rover Range Rover
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
When trying to start my 1999 GMC Jimmy I turn the egnition and all my aux. lights turn on and everything works, but there is no power going to my starter, it doesn't make the clicking sound and it...
check for power to starter solinoid, if power to there. then it has to be a bad starter solinoid or starter. checker solinoid first. if bad you will not hear any clicks or anything.
Sep 11, 2011 | 1999 GMC Jimmy
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
RCA F27242GY 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
