Region Code Hi, I wanted to know if theirs a code that I need to play all region dvd's on my DV7511NMC
  • sarast14 Sep 10, 2008
    The link worked but the link to download for the cd dosen't work.. I need help:(
  • imarc Oct 25, 2008
    I have the same problem...
DVD says wrong region ?
hi Nigel.
Region codes prevent playback of DVDs in other geographical regions. If you receive a region error while playing a DVD with RealTimes, this means that the region code of the DVD does not match the region code of the DVD drive. ... You can play Region 2DVDs only on a DVD drive that is set for Region 2.
Region errors when playing DVDs with RealPlayer - SUPPORT
https://customer.real.com/.../204041263-Region-errors-when-playing-DVDs-with-RealPl...
How do you change the region on a DVD?Click Performance and Maintenance, and then click System. On the Hardware tab, click Device Manager. The DVD Region tab might not be available for all DVD drives. To configure your DVD drive to play discs from other regions, select a geographic area from the list of regions.
(you could try this link but what ever it tells you to do you do so at your own risk.)
Make Your DVD Player Region Free in Seconds
Nov 18, 2017 | Televison & Video
Unlock region codes--change to multi-region or no region
You maybe able to get a Region free code from these WEB sites for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 12, 2013 | Samsung BD-E5400
The DVD player will not play anything. It says invalid region.
Then you have a DVD player that is either not designed to be sold in your region or DVD's that are for a specific region and not for the country you reside in. If you want to be able to play any video buy a multi region DVD player, not a locked to a region one! You may be able to find an unlock code, but oif its an unknown brand you're stuck!
Thanks for using FIXYA
Oct 10, 2009 | TruTech PLV16320 Television
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Regarding codes
hi janak911, Region coding is how Hollywood studios stagger dvd movie releases across the planet. These codes ensure that one country doesn't get a DVD movie before the same movie is out in that country's theatres. In their corporate omniscience, movie studios have carved the planet into regions with each region having a specific code.
All DVD players and discs have region codes. A DVD player and disc must be of the same region or the disc will not play.
If you want to watch movies from other countries, you need a multiregion DVD player. This will allow you to play any disc from any region. However, because TV standards differ, you might need a specialized NTSC/SECAM/PAL TV or a DVD player that can output any signal to the standard your TV accepts.hope u get the point.have a nice time.
raj..
May 12, 2008 | Televison & Video
Region codes reset
hi juferrer,i guess the dvd u have brought is from a foreign one. Region coding is how Hollywood studios stagger dvd movie releases across the planet. These codes ensure that one country doesn't get a DVD movie before the same movie is out in that country's theatres. In their corporate omniscience, movie studios have carved the planet into regions with each region having a specific code.
raj..
May 10, 2008 | Audio Players & Recorders
Zenith DVD Player--DVB410/ZND400
I got two new disks to-day with pictures taken from 35mm slides. They will not play on my zenith znd400 dvd player. I wonder why??????
May 10, 2008 | Zenith DVB412 DVD Player
Incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
Dec 05, 2007 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
