Question about Canon EOS-10D Digital Camera
Cleaning my sensor
I own a canon 10D and have a spec or something on my sensor. I know how to open up the camera to expose it, but am very uncertain of how to go about cleaning it. How gentle should I be, and what materials should I use? Thanx very much to anyone who can help.
    Sergeant:
  • 255 Answers
I have tried cleaning my 20D a few times. It is easy to do and the result is satisfactory. For routine cleaning, I just use a blower to blow off any dust on the sensor. Remember to turn the camera so that the sensor is facing down. In this way the dust once blow away will not fall onto the sensor again. For dirt that cannot be blown away, I use the Sensor Swab from Photographic Solution. http://www.photosol.com/swabproduct.htm They are very effective and easy to use but expensive (still much cheaper than going to Canon for service). Just remember not to add too much cleaning solution to avoid sneaking.
Posted on Sep 14, 2005
SOURCE:
Battery door
To purchase a battery door for your D10, go to eBay and search for "10D battery door." You will see several for sale and they run around $7.00.
Hope that helps,
BAX
Jan 07, 2014 | Canon EOS 10D 35mm SLR Camera
I have a canon 10D that is getting an "error 99".
You could've used a non-compatible lens or the contacts are dirty. Turn the camera off then use a clean micro fiber cloth or pencil eraser to clean the contacts.
Dec 17, 2010 | Canon EOS-10D Digital Camera
My Canon 10D will not Power On. Do I need the original battery ? Currently I have A battery from my Canon 30D in the 10D.
According to Canon, the battery should work in either camera. Does the battery work in the other camera but not in the 10D?
Oct 01, 2010 | Canon EOS-10D Digital Camera
I have a 10d digital camera. battery gos dead after shooting 15+
Try cleaning your battery terminals. You can use a little rubbing alcohol on a q-tip. If you are still having issues then you will need to get another battery as that battery is shot
May 27, 2010 | Canon EOS-10D Digital Camera
I have a canon ds6031 eos 10d. When I turn the camera on the view screen does not show what your pointing at. Is this normal?
Yes, it is normal. This is a reasonably old DSLR, and it's designed for you to look through the viewfinder (it's more accurate anyway as it's looking through the lens). You'll find if you keep one hand under the lens and one hand on the shutter, it'll feel quite comfortable to look through the viewfinder.
You can still view photos you've taken after you've taken them though.
Aug 31, 2009 | Canon EOS 10D 35mm SLR Camera
Need a canon 10 d manual
Manual for EOS 10D PLS RATE ME FIXYA FOR HELP
http://gdlp01.c-wss.com/gds/0900000229/EOS10DIM-EN.pdf
all downloads for EOS 10D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=325&modelid=8772
Apr 03, 2009 | Canon EOS 10D 35mm SLR Camera
Incorrect Light Meter
Make sure you have correctly set the Iso/ASA factor correctly and the flash is switched off Check out the Full manual which is a PDF file on the CD
Aug 05, 2007 | Canon EOS-10D Digital Camera
Canon EOS-10D Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
