Question about InSTEP AR166 Stroller
Stroller is swaying from side to side.
Called instep support, they said it was the torc in the front over the wheel. Did nothing. It sways side to side more if I am on an even surface.
  • 37 Answers
SOURCE: new wheel in instep duo stroller needed (BACK WHEEL)
I should go to he Pram Shop where you bought it from, if it has closed down go to a Mothercare Shop or similar Pram Shop. They will be able to get you the information you need.
Posted on Apr 08, 2009
SOURCE: Straps ripped on my Instep double jogging stroller (11-KA200)
Instep does have replacement parts for some of their strollers. For $25 I was able to purchase a new seating pad.
Posted on Apr 21, 2009
  • 10865 Answers
SOURCE: missing piece from InStep DuoCruiser wheel assembly
HI there. I can help you. here is the entire owner manual and parts list. find the part you need and you will also know what it is called.
Posted on Jun 23, 2009
  • 396 Answers
SOURCE: InStep Duo Cruiser front wheel C clamp part needed.
Search eBay or Google it.
Posted on Apr 09, 2010
  • 286 Answers
SOURCE: I need to purchase a
here are the contact details for instep they maybe able to help
Posted on Oct 22, 2010
Grinding noise front end left side at highway speeds and when turning wheel back and forth at high way speeds
Sounds like front wheel bearings.
Does the sound go away when swaying one way or the other?
If you way left and ot gets louder it should be the right bearing and opposite for swaying right
Jun 12, 2012 | 2004 Ford Explorer
Solid bar in front end, two bushings on either side of front tires is this the sway bar?
if you are talking about the sway bar end links. you can replace them yourself to save a few bucks. first Raise the front of the vehicle with a hydraulic jack. Place jack stands under the frame on each side of the vehicle. Lower the hydraulic jack so that the weight of the vehicle is supported by the jack stands and the front wheels are off the ground. locate the sway bar end links on either side of the front sway bar. Remove the bolts from each end of the sway bar end link. replace the bushings in the same order you take them off. you can go to any auto parts store and buy end links for your car.
May 04, 2012 | 2001 Chrysler PT Cruiser
94 ford thunderbird front end wheel assembly chassis bar that connects lower control arm to frame of vehicle in front end.
The bar would be the sway bar.
The parts that connect the sway bar to the lower control arm are called the sway bar links.
Oct 07, 2011 | Cars & Trucks
The bar in the front that looks loke a handle bar and has bushings what is it
If the bar goes from side to side it is called a sway bar. If it goes from one side to alittle past center it is called the stabilizer bar.
Jun 19, 2011 | 1997 Chevrolet Blazer
A mechanic said our daughter's 2002 PT Cruiser, limited edition , has a sway bar that is too long. In the Chrysler PT Cruiser manual I cannot find the sway bar mentioned and I don't know where it is on...
I dont see how it could be too long, if its the one the car came with. The sway bar would not be in the owners manual. Its in front and it goes from left front wheel to right front wheel. it will have a connector link at each end to connect to the lower arm. Sometimes it called the Anti-Sway bar or Stabilizer bar.
Dec 20, 2010 | Chrysler PT Cruiser Cars & Trucks
While driving over small bumps I hear a faint
there are many possibilties. Sway bar, sway busings, shock, tire, something in the brake pad, wheel bearing, the list goes on and on. Best bet is to let someone qualified to take a look and determin what's wrong before hundereds of dollars are spent without the cause being fixed.
Oct 31, 2009 | 2004 Chevrolet TrailBlazer
What is the purpose of the swine bar? The bar right by the tire. it has broke in my vehicle.
You mean the sway bar? If so, the sway bar or roll bar, or sometimes called the stabilizer bar. The sway bar has two functions.
  1. To prevent body roll or lean in a turn.
  2. It is used to control the handling of the vehicle and is tuned to your specific vehicle based on many characteristics.
You most definitely need to replace the broken sway bar. A vehicle with a broken sway bar is not a safe vehicle. The handling is not what it should be and this can be dangerous if you have to make a quick maneuver. Replace it, ASAP.
Sep 10, 2009 | 2002 Saturn VUE
2002 chry. Voyger has front end knocking noise when going over bumps.
Get someone to help you with this: Reach behind the front wheel just rearward of the strut and you'll find a vertical rod that bolts to the strut just below the spring perch and the other end goes to the sway bar. Hold it and get someone to rock the van as hard as they can. There's and astronomically good chance you'll feel a popping in this rod. If you do, you need to replace it. It's called a sway bar link. You'll need 2 of them and the sway bar bushings as well. Spray the nuts on the links down real good with wd40. Hold the back side with a pair of channel locks to keep the ball joints in them from turning. I take the top nuts off first, then the sway bar bushings so I can move that thing around to gain access to the bottom nuts. Then put them back in reverse order. Remember this, if you do it, no matter what anyone tells you, DO NOT lubricate the sway bar bushings. After the first rain, they'll start squeaking and they'll NEVER stop. They are supposed to go on dry.
Apr 13, 2009 | 2001 Chrysler Voyager
Front wheel
Sorry, but that is usually not a possiblity, but don't give up on just my say so. Contact the manufacturer directly and ask them to confirm. (800) 242-6110
Dreamer Design used to carry a swivel axis kit that would switch a fixed wheels to two small front swirvels, it may be a unuversal attachment. If you have no luck with InStep, try
Good Luck! from Moms Just Know
Oct 23, 2008 | InSTEP Ultra Aluminum Single UL100 Jogger...
InSTEP AR166 Stroller Logo
26 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
