The electricity went off and now only the main phone works and the other two say unavailable
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base
cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working
electrical outlet.
• Make sure the telephone line cord is connected to the base unit
and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another
phone to the same jack. If there is no dial tone on the second phone, the
problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to
the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button?
Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Help!!
I put the phone on the main craddle ant that work!!!!
Thank you very much!!
