Question about JVC Everio GZ-MC100 Memory Card Camcorder
Compatibility problem for the video files with Windows XP
There seems to be a compatibility problem for the video files with Windows XP (SP2). If I use Cyberlink PowerDirector, the programma that JVC delivers with the camera, the programma does not recognize the vidoe files as media files. Why?? What I do know is that the extension of the files is .mod (for instance: video1.mod). What can I do to import the video files and edit them?
    Master:
  • 903 Answers
I assume that you are using the firewire connection. Have you tried Windows MM2 in XP? Good info at this link. http://www.timwerx.net/odds/pcfile.htm
Posted on Sep 14, 2005
I have windows 7 and when i tried to install Oregon trail 5th edition on my computer, it said wasn't compatible and that the disk was never located.
right click on the setup file select properties then the compatibility tab set the compatibility to windows xp sp2 and check the run as administrator box. The setup file will be somewhere on the disc and will be a .exe or .msi
May 11, 2011 | The Learning Company Oregon Trail 5th...
I installed john deere american farmer to my computer but when i go to play it all the pictures are gone and words in the main menu
Are you running Windows Vista or 7? It says that it is designed for Windows 2000/XP. I would go into Control Panel: Add/remove programs. Uninstall the game.
Then find the executable file to install the game (assuming you downloaded it). Right click the file and select properties. Then find the tab called Compatibility and select the check box for "run this program in compatibility mode for:" then select Windows XP (SP2). then open and install the game.
After the game is installed, reboot. Once you reboot find the launcher file to start the game, again right click and do properties, make sure its set on compatibility mode for XP. that should solve it.
Jan 29, 2011 | Computers & Internet
Praetorians is not working in windows 7.... please suggest any soluntion
1- go to start menu
2- right-click on computer
3-click on properties
4-in the left bar click on "system Protection"
5- click on advance bar
6- in the performance click on "settings"
7-go to "data execution prevention" tab
8- click on "turn on DEP" and add you software .exe file.
9- enjoy!
if this doesn't work:
1- right-click on .exe file of your software (main file for running program)
2- click on properties
3- click on compatibility tab
4-in compatibility mode tick "run this program in compatibility mode for"
5- choose windows XP SP2
6-now enjoy!
Jan 10, 2011 | Eidos Interactive Praetorians for Windows
I have upgraded the O/S to Windows 7. Impossible to load a work:(
Try installing the driver in Compatibility Mode. Right Click, the main .exe, then simply choose compatibility Mode for XP SP2
May 26, 2010 | EzKey EZ-8000 Smart Office Keyboard
Shift2 USB 2.0 rechargable digital photo album N W!
You can try installing it in "Compatability Mode" for XP SP2 and Run As Administrator.
Windows Vista or Windows 7, has problems running some older versions of applications, just because so much has changed under the hood from Windows XP days.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu.
Select the Compatibility tab: Set it for "XP SP2"
You can actually hoose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can’t get things working. If you are trying to run a video game, you will often need to choose “Run this program as an administrator”. You’ll have to play around with it, but most likely you can get your application working this way.
Jan 24, 2010 | Audio Players & Recorders
I upgraded to windows 7 and now my linksys (WMB45G) wireless music bridge software utility doesnt seem to work anymore
It seems like a driver incompatibility issue. You may be need to contact linksys and see if they have a modern driver
Nov 27, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
An Epson RX620 Printer cant print from windows 7
I use the Windows XP SP2 drivers with Win 7. Before installing them, right click on the driver file, select properties, select compatibility and the select Win XP SP2.
Lou
Sep 13, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
NFS Most Wanted Not Working On Vista...........
Change the compatibility mode to Xp SP2
go to the program files and select the NFS folder right click on the exe file and change compatibility to WIndows XP sp2 it will fix
If not , then you dont have enuff graphic memory , u must disable the AERO THEME from vista and try to play
Sep 02, 2009 | EA - Electronic Arts Need for Speed : Most...
FSX Free Flight shuts off
I had this Problem It seemed to fix it when I ran the game in Compatibility with Windows Xp SP2 and Ran as administrator
To do this Right Click the Icon
Got o Properties
go to Compatibility tab
Click the Box That says "run this program in Compatibility mode for:"
and Windows Xp Sp2, Should be automatically selected
And at the Bottom Under "Privilege Level"
click Run as an Admin
Jun 02, 2009 | Microsoft Flight Simulator X for Windows
My game is loaded but when i click on the icon. it will not play?
Ok, from what I read on Microsoft, this software is NOT compatible with Windows Vista 32-bit or 64-bit. That was found directly from:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Software&p=School%20Tycoon&v=Take-Two%20Interactive&uid=&pf=0&pi=5&c=PC%20Gaming&sc=Strategy&os=32-bit
However, checking the company's website, it mentions that some games that normally won't run in Windows Vista, can be ran in a "compatibility mode" which mimics Windows XP. Follow these steps and see if this corrects the problem:
  1. Right-click the shortcut for the game.
  2. Click the compatibility tab.
  3. Check the box for "Run this program in compatibility mode".
  4. Select Windows XP SP2 (or Windows 98 if XP does not work) from the drop down menu.
  5. Click Apply
  6. Click OK
  7. Start the game
It should run in Windows XP SP2. If it doesn't you can try Windows 98 to be sure. If neither of these work, unfortunately, you may be unable to play this game.
Mar 04, 2009 | Video Game Consoles & Games
JVC Everio GZ-MC100 Memory Card Camcorder Logo
64 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
