Question about Haier Heating & Cooling
I have a Haier HWR05XC7 that will NOT work. The compressor turns on, but the fan won't work. The fan moves freely because I tried moving it with a screwdriver, but when I turn the unit on, the compressor kicks on, but no fan. I have been fighting with this thing for weeks and am about to chuck it out of the window. Also, the red error light stays on and there is nothing in the manual on how to troubleshoot it (other than making sure it is turned on and plugged in!). No support from Haier or Circuit City. I plan on bringing it back if no one has a solution. Thanks a lot.
  • Tricia Scerbo
    Tricia Scerbo Sep 02, 2008
    Also, I checked the Haier website for troubleshooting, the model isn't even listed! Circuit City won't help either, so it's going back. It's past the 30 days, but I will stand there until they credit my card.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
HEY< If you start out having problems , what do you think the future of that unit will be!
Posted on Sep 03, 2008
Motor seems to be working but fan does not turn.
NEED MORE INFO!!! Make/model of fan would be nice!
Mar 18, 2013 | Dryers
Lost remote, it only operates on low fan when I turn it on with the control on the unit.
I had the same problem, so out of frustration i kept turning the unit on/off button about 5 times real fast and wala it came on High speed Cool
Jun 20, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
Fan stopped working
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Jul 08, 2010 | Weather King 10AJA4201AH Air Conditioner
Fridge not getting cold tempture on high number 7 what should we do to get it runing
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 25, 2009 | Haier BC112G Wine Cooler
The compressor on my air conditioner was still running, but the fan was not running causing the temperature to climb in the house. I re-started the main power and the fan worked with the compressor wants...
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 20, 2009 | Heating & Cooling
Duo Therm kicking on the compressor, getting cold, but no fan!
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
The fan seem to have quit working and the unit got loud. i oiled the fan but it doenst turn on but the compressor comes on but overheats quickly.
Jul 31, 2009 | Dehumidifiers
The fan won't turn on one of my HWF05XC5's
unplug unit, remove the screws that hold on the front cover, pull off front cover and try to spin fan by hand. it should spin freely and feel smooth and take a while to stop; it should not have any play or feel rough, or stop suddenly. if any of the above problems are observed, the fan motor is bad if the compressor comes on but the fan does not. if the fan spins freely but just does not come on (and compressor does) it could also be a wiring issue. if you have no compressor or fan action, try another outlet and check to see if the breaker at the end of the cord is set to "on".
Jun 09, 2009 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Caleb Brunson
Caleb Brunson
Taylor
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
