Sound on home audio/video system not working
My TV,cable, DVD are all connected with my Rotel receiver. The sound doesn't work anymore with cable or DVDs. It comes on sometimes and then goes away. Sometimes if I change the channel the sound will come back on but then goes away again. And sometimes the speakers start to make a strange, static/screeching noise and then the sound goes out again.
Also, what would have made the system stop working correctly? And do you think it's definitely the receiver and not the speakers?
Thanks,
Jodi
4 Suggested Answers
  • 726 Answers
SOURCE: Rotel Receiver RSX-1067
the rotal reciver is on the way out to the bin ,,,i chucked mine out and got a new one and was all good again i had same problems thats all i have to say and i dont think there is a fix to that
Posted on Jul 29, 2008
AvioriX
  • 689 Answers
Hi Jodi
you can use alternate audio input/output, due to coupler issue sound might not work a particular channel.
please refer the user's manual and check alternate configurations has been indicated. click here for the user's manual
please post if you need further assistance
Good Luck
altonbtc
Rotel RSX 1067 is a good and powerful unit. But as stated over time heat and vibration will cause issues in these big A/V receivers.
I have repaired many, and for the most part it is solder connections on the power supply board feed-throughs and such. Loss of voltages to the digital board, or blown outputs caused by improper speaker wiring and or loads. All of the above is repairable but only with a very knowledgeable and person used to repairing these units. It is not for the DIY weekend warrior.
Posted on Feb 14, 2016
My suround sound works w/dvds how do i get tv volume to work in suround?
Hi Charles,
To hear audio from your surround sound (stereo receiver) the audio signal needs to be managed by the receiver. You likely have your DVD machine connected (going into) your receiver, then your receiver going into your TV --- your receiver is splitting the audio to the speaker, then the video to your tv. To get your TV signal split, you need to have your cable signal going into your receiver as opposed to into your TV directly.
Feb 07, 2015 | Audio Players & Recorders
I have an HK AVR 355 system, that worked just fine. Yesterday I tried to hook up a new TV, and ended up taking a few cable out since they were not imoportaint any more and only used HDMI cable. Now when I...
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Aug 17, 2011 | Harman Kardon Audio Players & Recorders
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
29 people viewed this question
 Grubhead
Grubhead
