Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Monitor goes black after being on for about 20 minutes
I am pretty sure this is a thermal problem with one of the components on the PCB but I am not sure if it can be fixed or not. Dell does not want to deal with it because I bought it from a 3rd party who removed the Dell ID tag.
What do you think?
  • jas0001 Mar 14, 2009
    I have the same problem and the monitor is only a few months old. This is horrible. It makes the monitor unusable. I am not inclined to get another Dell Monitor.
  • 88 Answers
This might be related to your system power options, if your monitor turns off after sometime (20 mins in this case) the best way to find out if this is caused due to a thermal reason - is to see if the monitor can work immediately after it turns off (coz, for thermal shutdowns it needs time to cool down before it works again)
Posted on Jan 12, 2009
Backlight turning off when the tv gets hot
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 06, 2014 | Televison & Video
While i am on my computer my hp w1907 monitor goes black. if i shut the monitor off and wait a few minutes it will come back on but then it only stays on for a couple minutes and goes black again.
This sounds like a power board problem. Could be failing power capacitors, which are allowing the charge to leak ( stripping the screen, not recommended) will show bulging or leaking capacitors). Or it could be an issue with the PCB. The fact it will restart once it has "cooled down" points to this.
I'm assuming you have tried the monitor on a different computer, just to eliminate the graphics card (unlikely but worth a go)
Solution..get it checked by a qualified TV repairman, it may a be a simple fix.
Jul 13, 2011 | HP w1907 LCD Monitor
My GNR F173 makes a squeky noise when switched on and the screen goes black. After switching on again (several times) it works fine. Can this be fixed? Will it be worth the cost if it can?
gwyn1william, Monitor printed circuit components are all "working" !!!! That's good!! You need to see video clips at YOUTUBE!!! Learn how to do soldering. Then use very large magnifying glass or use inspection grade microscope (4x to 20x) to find the 1 maybe 2 "hairline fractured,thermally intermittant" solder connection of the leads of the devices (active or passive) which are causing this condition and will need to be resoldered. ($20 or less DIY) ($40 to $80 contracting out the work) Then and only then return to fixya and rate this as to it's usefulness to you in solving monitor problem. 12fixlouie
Sep 13, 2010 | Gateway FPD2275W LCD Monitor
Sony Trinitron KV-2726R Goes out after a while
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 15, 2017 | Televison & Video
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Samsung DLP Problems
Possibly thermal sensor,ballast,or the lamp or all of the above,or the main pcb could be the culprit
Dec 12, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Going Black
Sounds thermal runaway. A component is getting too hot and failing. It will cool down and then work for a bit. Pull the covers to access all the boards and get a can of freeze it spray. You can identify the suspect parts with that.
Nov 05, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
17"LCD Monitor
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area.Check this link to get the service center info
http://www.lgservice.com/
Oct 11, 2007 | LG L1915S 19" LCD Monitor
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
599 people viewed this question
Alun Cox
