Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Dell Latitude C600 Laptop
Problems:
Can't retrieve Start Menu
Error Message: Primary Hard Drive O Disk Not Found
Thank You!!
joannfarley@bellsouth.net
  • Anonymous Dec 16, 2008
    i have the same problem mine says
    primary hard drive 0 not found
    no bootable devices
  • 702 Answers
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Posted on Sep 03, 2008
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
Older dell latitude cpx running XP. yesterday after loading firefox and a few mozzilla add ons .. today I boot to error 0 no primary hard disk found.. bios says no hdd installed ????
Hello, Jay.
Well, as the message indicates, your hard disk drive is failing or failed. Try running your diagnostics to verify (boot and press F2 or F12 repeatedly).
If the hard drive is failing, see if someone locally can help to retrieve your documents and other files by removing the drive and setting up the drive as a slave drive on another computer.
The drive would then need to be replaced. Price the same type of drive but it may not be cost-effective to use another drive in this computer.
Hope this helps.
Oct 18, 2011 | Dell Latitude CPX Notebook
I have two Dell Latitude Laptop C500/C600 exhibitting the same problems with detecting the primary Hard Drive. The drives show up in the Bios (I have tried several drives, all pulled from other working...
if hdd is detected in the bios but cannot be detected when booting to windows then do this.
1. turn off laptop, press and hold on the Fn key then press power button once
2. psa test will run and check if it shows your error codes such as 0141 - 0142 - 0146 this means hdd needs replacement.
Oct 14, 2009 | Dell Computers & Internet
Dell latitude c600 primary hard drive not found
that means the storage system's MAIN drive, (the C: drive, the hard drive, the hard disk) is not working, OR, is not being seen by the computer. Try removing and reinserting the drive, or take it to a shop to have the drive tested. The c600 was usually very durable, and it is likely the PC itself is fine, and you just need a replacement hard drive. But the BAD news is, if your hard drive is toast, then so is the operating system, which means that would have to be reinstalled as well. the c600 usually came with Windows 2k, 98SE, or ME. If you are "tech challenged" like you say, your BEST option is take it to a local shop, and tell them the hard drive failed. MOST shops will charge about 30-50 bucks for a 40-80 gig hard drive, and charge about 100 bucks to reinstall Windows and drivers. AS LONG AS YOUR WINDOWS PRODUCT KEY IS ON YOUR MACHINE AND VISIBLE you wont have to purchase a registration. IF HOWEVER, your key is MISSING or unreadable (wear, scratches, etc) you will have to purchase a license from Microsoft, if that is the case, then go ahead and purchase a copy of XP have them install Windows XP and drivers for you. USUALLY, a pc shop will install purchased software for free.
Aug 28, 2009 | Dell Latitude C610 Notebook
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
BIOS screen says no primary hard disk, then "no bootable device available", now I have blue STOP screen with instructions
the hard drive may be bad. try re-partitioning the drive. if that doesn't work the hard drive will need to be replaced. if you still have warranty dell will replace it for you for free. www.dell.com/support. if you do not have warranty you will need to buy a new one for your computer. best buy sells them cheap. thank you for using fixya
May 01, 2009 | Dell Latitude C600 Notebook
My dell ppo1L C/600 latitude won't boot
hello, seems like your hard drive have errors. replace the hard drive and reinstall the computer and your computer gonna work.
Mar 10, 2009 | Dell Latitude C600 Notebook
Primary hard disk drive 0 not found
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
Dell Latitude C600
Yes, No problems as I put a 100GB drive in the LS model micro Latitude!
Aug 06, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Computers & Internet Logo
261 people viewed this question
Alun Cox
