Whater leack around heating/cooling system - Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
With good problem descriptions, comes good answers, Check filter -- plugged drain line, somehow add some bleach to the drainage system or blow the line clear with preassure or water!
Posted on Sep 03, 2008
I have a older Carrier heat pump, model 38YKC060. Does anyone know how cold it will continue to work at?
Heat pumps are of little or no value at temps around 40 degrees or below. And if you use the strips it will cost a small fortune if you have relatively high electric rates as most folks do.
Jan 04, 2017 | Heating & Cooling
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Only recently my portable heller air conditioner is oosing out buckets of water each night. does it mean it finished and needs replacement,
Portable air conditioners cool the air, and in so doing, dehumidify the air. The "buckets" of water are coming from the humid air in your environment, so you need to do things that will reduce humidity, of be prepared to empty the condensate receptacle fairly often.
Using a small room, closing doors and windows to the room you want cooled, avoiding cooking or heating water, reducing the frequency of people walking into/out of the room and limiting the number of people in the room will all help in reducing, and keeping low, the ambient humidity.
Jan 03, 2015 | Heating & Cooling
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
Dec 27, 2014 | Heating & Cooling
Repair infrared space heater
It might have a fuse that has been blown internally. This may have happened to protect it from over heating because it was left on too long or something went bad and it got too hot.
Dec 08, 2014 | Heating & Cooling
Why does home central air conditioner will only cool to 80 degrees?
Because it is low on Freon. Do not run it low or the compressor wont be able to cool and you will burn it up. If it has run more than 1 hour in 90 degree heat the compressor is probably already damaged. Have a HVAC professional look at it, but if you were still using id plan for the worse, a complete replacement.
Jun 29, 2014 | Heating & Cooling
Heat will not blow hot air model #310aavo48090oabjd serial #0205a42429
give name make of unit and set up of system oil/gas ect...
Oct 28, 2012 | Heating & Cooling
John Deere lx178 cooling fin
If you insist on utilizing an usb 3. car charger, purchase only a brand name-name charger because they typically have a higher high quality fuse to protect your device. Tips For Longer Cell Phone Battery Life AmanStino
Jul 16, 2012 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
