Question about SMC Barricade 7004 Router
I have a SMC Barricade SMC7004VBR but can't set a password for wireless acess. The ecryption or secure system i realy don't understand. I use the codes of numbers an when i try to acess the wireless ask me for a password! Thank's
3 Suggested Answers
SOURCE:
  • 104 Answers
SOURCE: Secure wireless connection to the internet.
Hello Peter, I'll try and help if I can. I'm assuming you're using Windows XP.
First, when enabling security on your router, it is best to connect using a wired, rather than wireless connection.
Open your web browser, as if about to view a web page, but instead type the address of your router in the address bar. I think this is http://192.168.2.1 (Note there is no 'www'.)
If successful, you should see a screen asking for a password. The default is set as blank, so just click 'login'.
You should see a home page. Click the option for 'Advanced Setup'. Then click the left hand menu item, 'System', then 'Password Settings'.
You should see a screen where you can change your current (blank) password to a password of your choice, and then confirm the choice (it should have 3 to 12 characters, letters and/or numbers). Click 'Apply' to save the settings.
To secure your router, there are a couple more steps to follow. Click the 'Wireless' option on the left hand menu. Under 'Channel and SSID', you should see a screen which shows your SSID (a name for the router)....It is a good security idea to change this to another name - anything you like, as long as you can remember it! Click 'Apply' to confirm the new setting.
Then select 'Encryption' from the Wireless menu. Select 128 bit WEP encryption. You should see a box asking for a 'passphrase'. Enter any phrase, made up from letters and numbers, with no spaces, and click 'Generate'.
I hope you will then see a series of numbers split into boxes. Write down the numbers in sequence (or maybe you could print the screen?). This is your encryption key. Click 'Apply' to save the settings.
You can then exit from this screen.
The last thing to do is set up your wireless adapter connection (eg, a laptop, or whichever computer has the wireless connection). When your wireless connection tries to access the internet, you should see your router with its new name come up in the 'available networks'. Click to connect, then enter your WEP key when prompted.
I hope this helps you. I'm not a pro, just lending a hand, so please come back to Fixya if anything is not clear, or doesn't work as expected! All the best.
Posted on Dec 10, 2008
SOURCE: Need password for log in to SMC Barricade 7004 VWBR Router
The username could be: admin
and the password could be: passoword
the password could be: admin
Posted on Jan 01, 2010
I don't know how to set up a password for my wireless internet connection. How do I do it?
First you connect an ethernet cable from your computer to one of your lan ports on your router. Then you go to http://192.168.2.1 and log in with the credentials username:admin password:smcadmin. From there you can change the wireless password in the settings. Sincerely, Nick
Jun 23, 2011 | SMC Barricade N Wireless Broadband Router...
Op de SMCWBR14-G2 sttat geen reset toets op. Hoe kan ik deze router dan resetten?
Probeer:
Well, once reset you will need to login to the interface and resetup all the connection information. You can do that from the WEB interface just logon and reset. No special software (except a web browser) is needed.
I think the SMC default address is http://192.168.2.1 just log on and set it up. Resetting just restores the factory defaults, it does not erase the system.
Rarely does a router need software on a computer. Even the linksys that have a big sticker USE CD FIRST -- its only there for those who don't understand routers!
There is a good help forum for SMC at
http://www.dslreports.com/faq/smc/3.1_Th...
Jun 12, 2011 | SMC Barricade g SMCWBR14-G2 Wireless...
How do I password protect my smcwbr14t-g router?
hello and welcome to FixYa;
connect to the barricade via an Ethernet cable.. then.
click this link
192.168.2.1
Then.
You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
Click the Wireless > Security link from the page menu on the left-hand side.
1.
On the Wireless > Security page, you can retrieve your password(s) from the fields to the right of the Pre-shared Key (PSK) > entry. (in the gray box menu on left)
2.
Uncheck the Obscure PSK box to view and retrieve your password(s). You can add a password at this point and click apply changes.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 31, 2011 | SMC Barricade g SMCWBR14T-G Wireless...
I want to change my security setting on my network so that my psp will support it. How can I do it without the disk
Welcome to Fixya. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.2.1 The Default password is smcadmin. Password is case sensitive. Click on Wireless and then select Security. You can now change the security settings of your router. You can also refer to the manual below.
SMC Barricade SMC2804WBR Manual
Thanks for using Fixya.
Mar 12, 2011 | SMC Barricade g SMC2804WBR Wireless Router
I am having difficulty making my network a secure network, how do I access the routers setting to enable the password?
Connect a LAN cable from your computer's LAN port to the SMC wireless router.
Open a browser and enter the SMC configuration URL.
http://192.168.2.1
The default PW = smcadmin
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 20, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
How do i set the password for my wireless and i using the SMC router now. Pls help, people are keep using my wireless and my internet keep disconnect .
Setting up a login password only protects your wireless router from someone changing your wireless settings.
To secure your wireless network from unauthotized access, please click on this link and follow my instructions :-
Sep 21, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Password
Go to the SMC site and download the appropriate manual.
For Windows XP, it says:
"To access the Router’s management
interface, enter the Router IP address
in your web browser http://
192.168.2.1. Then click LOGIN.
(By default, the password is
smcadmin. The default is case
sensitive.)"
Once you are logged in, you may change your password under the System -> Password Settings section.
Please Approve of this answer if I answered your question.
Jul 20, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
How do I set up password protection for my SMC Barricade Turbo 2404WBR Router?
Please follow the steps mentioned below and check if the issue is resolved.
  • Please open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
  • The password would be either blank or smcadmin.
  • To enable Encryption or Secure the Wireless Network, follow these steps:In the router's configuration page: Click on Advanced Setup -> Wireless -> Encryption.
  • Select the Encryption type (WEP, WPA, WPA2 etc), type the Security Key and save the settings.(128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9
    64-bit encryption uses 10 characters. Example:
    01 A3 45 F7 8)
  • The Wireless/Internet is Secured Now.
  • You can also set the password for the Router log in: Please click on Administrator settings and input the new password.
Good Luck!
Thank you for contacting.
Jul 07, 2010 | SMC Barricade Turbo Router
Jan 01, 2010 | SMC Barricade 7004VWBR Wireless Router
The default password isnt correct, cant log in. I reseted the device many times, and unpluged for hours/days but the default password still doesnt set back...so i cant use the device because with default...
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Oct 12, 2009 | SMC Barricade SMC7004VBR (SMC7004VBR-CA)...
SMC Barricade 7004 Router Logo
91 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
