Question about Bosch Washing Machines
I have a bosch wfk 5730 washing machine has been very reliable but now continuously keeps taking water in to machine, at timer position "F", just before the final spinning cycle begins, till it over flows and floods the kitchen area. Is this a simple fault of a faulty valve/solenoid or is this a module fault, please help Kind regards mike
Could be an iffy valve/ solenoid. One test is to see the empty machine slowly fills up with water, if you leave it for a few days. You can isolate teach valve by turning each feed off in turn. i t could be leaking all through the cycle. If it is flooding during the spin I'd check your pump at well. Hope this helps.
Posted on Jul 31, 2010
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 hot water wont shut off even if you turn power off
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
Jan 07, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
My Bosch WFK 2401 keeps giving me the 03 error message, the pump looks fine when I drain it manually (which takes 1/2 and hour!, now I don't bother draining it completely, I just drain a bit of water from...
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Oct 05, 2008 | Bosch Washing Machines
WFK 2401
Replace hot water valve.
Aug 13, 2008 | Bosch WFK 2401
Washing Machines Logo
292 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
