Question about Samsung ML 2010 Laser Printer
Is the leader part of the toner cartridge?
Thanks for responding. For clarification: is the leader you mention part of the cartridge or the printer itself? From what you wrote, I'm thinking it's not part of the cartridge, but underneath. (I don't have my printer in front of me at the moment.)
What causes such cracks? I'm pretty sure I didn't abuse anything, and I got through the "starter" cartridge just fine.
Also, is there anywhere one can go to find a good set of diagrams/descriptions of what a particular printer does during a print cycle? I suppose it's too much to hope for, but I'd *really* like to see an animation, ideally.
    Sergeant:
  • 293 Answers
Yes the leader is the control unit that guides the cartridge across the paper along with the print head. Cracks can occur when a cartridge is misseated or just from age.
Posted on Sep 12, 2008
Toner cartridge appears
I share a informative link, please visit and read it. I hope solved your issues.
REPLACEMENT OF TONER CARTRIDGE and Replacing the Toner Cartridge Print Cartridge and any help.. HP Printer Support
Thanks,
Sep 17, 2014 | Office Equipment & Supplies
A white streak appears on the right hand side of the print out
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | Epson Aculaser C1100 Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
The bp20n ran out of toner. We put in a new
I have to respond to this posting with a solution because I cannot track responses if I mark this as a "Clarification".
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | Ricoh Aficio BP20N Laser Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
Prints lightly and unevenly even though toner levels OK
have you tried reinstalling the drivers? maybe getting updated drivers off the internet might help you out more.
thanks
tom
Dec 20, 2008 | Samsung CLX 3160fn All-In-One Printer
HP 2605dn- replaced all toner cartridges now it won't print-
There might be a problem with the network connection. Is the cable connected to the back of the printer?
The printer could have lost the connection.
If the printer is able to print a configuration page and if the display responds to comands from the buttons in the display panel there is a very good chance the network connection was lost.
Yo mentioned "paper jam" is the printer identifying a paper jam?
Nov 19, 2008 | HP Color LaserJet 2600n Printer
Printer not responding after a jam
http://files.oce.com/nl/download/printers/PP20D%20Operation%20Guide%20(Engelstalig).pdf Here is the link to the pdf manual for the printer. They show some light sequences and mention something about the old toner cartridge may need to be emptied/replaced. I'll let you know if I think of anything else. Tim
Jan 29, 2007 | Kyocera Mita FS-1020D Laser Printer
Samsung ML 2010 Laser Printer Logo
89 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
