Brother hp-1240 laser printer. won't print. blinking red "alarm" light
5 Suggested Answers
printech
  • 159 Answers
SOURCE: Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Posted on Apr 03, 2008
printech
  • 159 Answers
SOURCE: Ready and Alarm light keeps blinking on Brother HL-1240
check the sensors maybe stuck
Posted on Sep 06, 2008
rscheutz
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
  • 526 Answers
SOURCE: We have a Brother H
generally, if the alarm data are blinking every 5 seconds, that indicates the toner is low.
there are no other possible errors. may be your toner is completely empty as well. are the other 2 lights blinking or on?
Posted on Apr 17, 2009
  • 114 Answers
SOURCE: Brother Hl-1240 laser printer all 4 lights started
main board pcb need to be replace.
Posted on Jul 18, 2010
When I turn on the printer, the data and alarm lights come on. There is nothing in the printer que. I have power cycled the printer. I was trying to print a pdf file.
From the Service manual:
Toner low: The Data and Alarm LEDs blink once every five seconds.
Toner empty: The Data and Alarm LEDs blink once every second.
Alarm & Data LEDs are ON: Toner empty
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 11, 2011 | Brother HL 1240 Printer
The alarm button keeps blinking. How do I get it to stop?
Well I'm sure that the alarm button is blinking for a reason. I beleive that printer is a laser so unless you dont have paper in it :)
You most likely are low on toner or need to change the drum.
Jul 28, 2010 | Brother HL 1240 Printer
I have a brother hl-1240 that has both the yellow data and red alarm led's lit. and it just printed 10 blank pages
make sure your catridges are full because some printers don`t let you print at all even if only one catridge is out
May 16, 2010 | Brother HL 1240 Printer
HL-1240, the alarm light is on, what would be the reasons?
the first alarm light (at the very top) indicate the toner life ends the second light(middle) indicate the drum life ends and the third is for paper jam or print error
Sep 18, 2009 | Brother HL 1240 Printer
Brother HL-1440 LASER PRINTER requires ''Service Call A''.
currently, the error you have is not a service errorl, ready and alarm blink means that you have either a paper jam, no paper, or a paper misfeed.
do you get this error only when you try to print?
according to the service manual the lights can not alternate in blinking.
May 30, 2009 | Brother HL 1440 Laser Printer
We have a Brother H 1240 Laser printer. The alarm and data are blinking and it will not print. I have tried to reset with no results. Can you tell me what to do?
Apr 17, 2009 | Office Equipment & Supplies
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
