Question about Honeywell Heating & Cooling
Got a honeywell t8400c thermostat i'm trying to replace with a honeywell rth3100 honeywell thermostat but only have yellow green red and white wire on the old and don't know where to put the wires on the new
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
R--- rc or rh y--yellow g---green w--white red is power yellow is cool g--fan white is heat
Posted on Sep 03, 2008
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
RTH3100C thermostat Have 4 existing wires; Yellow(cooling),white Heating) green (Fan) and red (power) WWhat terminals to use at above stat?
The RTH3100 is a heat pump stat. Your wires indicate that you have a 1h/1c operation. This is the wrong stat for your application and will not work.
Oct 10, 2009 | Heating & Cooling
Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Sep 18, 2009 | Heating & Cooling
I'm installing a Honeywell RTH7600B programmable thermostat and replacing a Honeywell T87F2873. The new one calls for a Red, Green, White, and Yellow wire, while I only have a Red, Green White and Blue....
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Jan 16, 2009 | Heating & Cooling
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
760 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
