Question about Dell Axim X5 Pocket PC
Type 1 CF Cards
Does anyone know if Type 1 CF Cards work with the Axim?and what is the difference between Type 1 and Type 2?
    Master:
  • 852 Answers
No, the number of pins is identical. Type1, type2 refers to the THICKNESS of the card, Type 2 cards are about twice the thickness of type one. Since the Axim has a type 2 slot both type 1 and type 2 cards will work.
Posted on Sep 14, 2005
    Master:
  • 852 Answers
They will work. The only difference is the number of pins.
Can I use Standard 4G or 8G SD or Cf cards in a Dell Axim X5?
SD cards must be SD not SDHC, there is not an SDHC driver for the X5. You can find regular SD cards up to 4G.
CF is no problem, all flash based CF cards will work. Microdrives can be problematic.
Dec 20, 2008 | Dell Axim X5 Pocket PC
My DELL AXIM X5 CF SLOT not fuctioning
Check the pins inside the slot. I had one that bent and the cards were no longer recognized
Sep 14, 2008 | Dell Axim X5 Pocket PC
Sdio Wireless Lan Card Wlan 802.11b
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Jul 29, 2008 | Dell Axim X5 Pocket PC
Axim Data Backup Does Not Work
After doing a soft reset to enable Clear Type, I tried a backup of all data and everything worked! Nor Backup Failure Message and the backup file can be seen on the CF card.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Speed of CF vs SD in Axim
The reason CF COULD be faster is that it is a parallel connection (16bit IIRC) while SD/MMC is serial in nature. Now, assuming the INTERFACE were the limiting factor in the speed this could become significant. Unfortunately the interface is NOT the limit (in most cases), the limit is the actual fetching of data from the memory itself. Being Flash it is nowhere near as fast as some of the other types of memory we are used to. It is especially slow when being written to. Newer cards out there are faster then older ones, but in the end I doubt you would notice much if any difference between the speed of a CF versus an SD/MMC card
1GB IBM Microdrive
I got my 1gig microdrive last Wed. UPS says my Axim is going to be delivered today. I'll let you know how the microdrive performs as soon as he axim is charged.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
Secure Digital Wireless card?
No. The secure digital on the Axim only supports memory cards. If you want to use anything else it will have to be for the cf in the Axim. Devices for wifi, bluetooth, and modems are more readily available for cf and are lower priced at the moment too.
Is the Axim compatible with IBM 1 Gig MicroDrive? As this is the only way to put full length feature film onto the PocketPC platform. I know that the Axim has a type II Flashcard slot but want to make...
The advanced Axim appears to work fine with the 1GB Microdrive. Just appears as a "CF Card". MP3's etc play fine from it with no noticeable problems.
Dell Axim X5 Pocket PC Logo
107 people viewed this question
Alun Cox
