Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Leaking from bottom front
Our washer started leaking from the bottom front portion of the unit. Any suggestions? We turn the water off to keep leak from continuing. I can still do laundry with the leak, but of course not safe.
Today I spent the morning on the same problem. I found there is a white plastic component that has a gear like wheel inside and inlet and outlet to the hoses (one from the drum and the other smaller one to the drain). Probably this is the pump that 'oldfixer' is referring to? It was easy to remove and I found in the middle of the plastic top of this piece has a small hole and I just ran some water through this (after removing it from the washer) and confirmed thats the hole that is flooding my laundry room. Anyway, I applied some KwikSeal (is that the right thing to seal this? Thats all I've in the house right now, but if someone suggests a better way to seal it that wld be great!). Anyway, I'll let it dry fully and then retest with water. If ok I'll just fix it back into the washer.
Hope this helps
Posted on Sep 07, 2008
  • 1,028 Answers
Lean washer to back ..pump mounts just underneath 2 clips hold pump too motor shaft remove clips remove hose clamps ckd pump most likely suspect for leaks
Posted on Sep 02, 2008
My washer is leaking water
Frigidaire washing machine leaking water from bottom
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
Water leaks as you fill it
The most common part that leaks is the drain pump. Remove the two screws at the bottom edge of the front of the washer panel. Then with both hands slap the front panel in a downward motion to remove it. You will then be able to see where the water leak is coming from. Start a wash cycle and look for the leak. keep your hands and curious pets out of there while the panel is off and washer is running. turn off the breaker or unplug the unit if you step away from the machine and leave the panel off. If it is in fact the pump that's leaking it's very easy to replace. As you can now see, Just two clips and two hoses. Here's the part this helps. Good luck,
Mar 22, 2015 | Whirlpool Thin Twin Washer and Electric...
I have a miele dishwasher model G2270SCVI it is about 8 years old.It has just started tripping the meterbox every time we turn it on for a cycle{after about 2mins}i have removed the metal toe plate and...
Water in the under side of the washer is probably shorting the unit out, making for a potentially very dangerous and potentially lethal hazard.. Turn the breaker off to the dish washer until you have figured out where the leak is coming from. Is it from the supply line that feeds the water to the machine or is the tub leaking. I would guess the water supplu line is leaking.
May 24, 2014 | Dishwashers
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
The front lower portion where the receiving hose and the draining hose meet appears to be the culprit in the leaking of my washer. A plastic housing.
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
Water is leaking from my wash machine
Ifit is from the front middle of the unit that is the water pump they are made of plastic and can start to leak best was to check is to tip the unit back a little and look
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
