Question about HP iPAQ RX3715 Pocket PC
Loss of memory
Hilst switched off I lost all power to my rx3715. I recharged it but then found I had lost all data in the memory. The back-up battery was still showing 100%. Any ideas?
    Problem Solver:
  • 15 Answers
The back up battery always shows 100%, as far as my experience shows. The backup battery is only utilized to retain memory while the main battery is dead. The backup battery charges first, so if the ppc has enough juice to be turned on, the backup battery should be at 100%, unless it is plugged in and you are just now turning it back on. Even so, it will probably still show 100%.
Basically, you left it on too long and all the batteries died. Sorry, but your data is gone :-(
Posted on Mar 01, 2008
Does the gt10 have an internal battery for the user memorys if so how long does it last
Generally, any unit such as this will have a backup battery for the user changeable areas' memeory. The normal span is 6-8 years, but i change all mine at 5. You should read the manual for your device and/or contact Roland customer service. Here's the info-
http://lib.roland.co.jp/support/en/manuals/res/1810803/GT-10_e2.pdf
Roland Support
Mar 17, 2016 | Music
How to format 3230
Before you format your phone, you should back up your data, to avoid any data loss.
How ever, data in your memory card and SIM card will not be lost during the formatting process.
To format your phone, follow these steps:
1.Make sure you have at least 3/4 charge of battery power left.
2.Switch-off your phone.
3.Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
4.Remember, do not let go all of the keys, hold until you see a formatting word screen show!
5.After a few minutes when the full phone formatting completed, your phone will be back to original system and factory settings.
Thank you for using Fixya,
Kenneth.
Mar 02, 2010 | Nokia 6600
Sony mdm-x4 when I load a disc it shows me blank disc, before that TOC reading. how can I get my record back?
You cannot remove power from a minidisc player after you are done recording as it updates the TOC when you power down. If you had switch set to timer "REC" and power up the unit it should update the TOC, otherwise all is lost.
Jan 22, 2010 | Audio Players & Recorders
Data missing - Ipaq model HP5555 - did not do hard reset
I'm sorry but the HP Ipaq 55xx series store data on a volatile ram based memory. Unlike a nand flash (like usb sticks, memory cards etc) this memory will hold data only as long as it's powered on. If your main battery gets empty you should still be able to retain your files for some 10-20hrs with the backup battery (if it's ok itself and not depleted). After this time the power to the ram memory is cut off and all data is lost.
The problem you face is somewhat related to that backup battery, as it appears it's unable to do it's job and maintain the power to the ram memory at least some 10 hrs. You should have that battery replaced.
There is no way to recover the data from the ram memory as it is stored as an electric charge over some memory cells in the ram chips. When there is no power, these charges dissipate and the pattern is lost.
I'm sorry for having to give the bad news.
Bogdan
Jul 03, 2009 | HP iPAQ H5555 Pocket PC
Lost Data
The simple answer is.. i'm sorry to say it so simple.. no. Here is why. PDA's have volatile RAM memory. This means that when the battery, back-up battery are completely drain out, they cannot keep up powering the RAM memory. When the power cuts off, everything in the RAM memory is lost. The operating sistem and other files specific to it, doesn't get erased as they are stored separately in another kind of memory called ROM. This doesn't get errased when power drains out. The reason why PDA's doesn't have only ROM is because this type of memory is slow and the PDA will operate (read or write data to it) in the same slow manner. Therefore they use the RAM memory wich is faster. The best advice I can give you now is never to let the main battery to drain out completely. Also regular back-ups of the data inside the PDA are usefull for situation where unexpected occur. Feel free to ask more questions and always remember to rate the answers provided from this site ;). Good luck.
Feb 24, 2007 | Palm Tungsten T3 Handheld
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Rx3715 battery power trouble
Did you check if the PDA was hot? My battery was totally dead one day when I picked my 3715 up, just to found out it was blistering hot (was turned off) and even the backup battery was empty. Running fine now after hardresetting it, but still...
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
157 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
