Question about Vtech IS6110 1-Line Cordless Phone
No dial tone
I have MSN messenger all set-up, how ever the hand set has no dial tone, says failed to connect to home
Thank you
Kimberly Barnett
kimiecake@yahoo.com
3 Suggested Answers
  • 3 Answers
SOURCE: can not break through dial tone on either hand set
After going around and around and around with YOU people, I finally gave up and took the damned phone back to the store where I bought it. The first store wouldn't take it back, because I had the receipt (which was from early September, 2008 - which was past the 90 days), so I took it to their other location and told them that I lost the receipt. I got a brand new replacement. If the new one should fail to work, I'll take it back again WITHOUT the receipt, and upgrade to another brand. Thanks anyway.
Posted on Mar 28, 2009
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
Error code: 80072efd
If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
1. Click the Tools menu, and then click Options.
2. In the left pane, click Connection.
3. Under Connection Settings, click Test Connection.
If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
4. Optional: Perform advanced troubleshooting
To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
5. Click OK.
When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
6. Try signing in to MSN Messenger again.
Hope I helped MSN expert Dr Reed
Oct 25, 2009 | Microsoft Windows Live Messanger
Cannot connect to isp using modem (dialup) get error code 680. using vista home premium.
error code 680 means there is no dial tone.
manually attach a phone to the phone jack you are connecting to and check if there is a dial tone. if there is no dial tone on that jack try a diff phone jack. if still fails call your telco.
if there is dial tone to other jacks it means the previous jack is faulty or damage.
Oct 17, 2009 | Computers & Internet
How to remove msn
I take it that you don't wish to use MSN for internet access. You can delete it from your network connections window.
Then you will have to set up a connection that will use either dial-up or some form of high-speed connection. That will become your default connection.
Oct 08, 2009 | Microsoft Windows Vista Home Premium with...
Olve error code 80072ed quickly and easily
5. Click OK.
Sep 25, 2009 | Microsoft Windows Live Messanger
Cant sign in to wlm
5. Click OK.
Sep 16, 2009 | Microsoft Windows Live Messanger
Cant sign in to MSN Messenger it says Temporary Problem when i check the service site it says its running think i deleted a file
Hi there, my name is Alex and I am here to help solve your problem
A common problem to signing in to MSN Messenger is the date and time set incorrectly. You can locate this at the bottom right hand corner of the desktop. After setting the time and date correctly, you should be able to sign in without problem.
If Messenger gives problems and the date and time are both set correctly, exit MSN Messenger and exit the icon which is located in the system bar (next to the time and date) and then open MSN Messenger again.
I hope this problem helps..... If you have any questions or more problems, please feel free to ask me.
Nov 27, 2008 | Microsoft MSN Messenger Connect for...
MSN MESSENGER
Click on your START buttonthen choose Control Panel from the right hand side list....... Then from the text on the left top of page, choose "View Classic Mode" then in the right side of screen, choose the FIREWALL icon.... click on it and in there you can either turn off the firewall or adjust it to allow msn through in the Advanced settings..
Jul 07, 2008 | HP Pavilion dv6000z Notebook
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
Jun 23, 2008 | Brother IntelliFAX 2800 Laser Fax
Vtech IS6110 1-Line Cordless Phone Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
