Question about Garden
Motion drive belt on craftsman riding mower
I have replaced the v belt on my riding mower. It worked fine until it jumped the track along the transaxle pulley. The old belt is chewed up in the same location as the new one. If I could tighten the belt once it is installed that probably would take care of this problem. I do not know where you adjust the tension on the belt once you put it on. Please tell me how to adjust the tension on the v belt. PS It is not in the manual.
  • 3 more comments
  • OTSMITH216 Sep 04, 2008
    CAN'T ENGAGE THE BLADES, HANDLE TO ENGAGE IS WEAK, CK & NO BELT IS BROKEM OR MISSING, THIS IS A MODEL DLT300.THANKS
  • Anonymous Oct 19, 2008
    NO BELT IS BROKEN OR MISSING,
    THERE IS A SPRING THAT IS CONNECTED TO THE ENGAGE HANDEL CABLE AND IT HOOKS UP TO THE TENSIONER THE SPRING IS BROKEN OFF.
    I WOULD LIKE THE PART NUMGER OR A PIC OF THE SPRING SO I COULD SEE IF I CAN STRECH IT AND HOOK IT ON ..
    THIS IS A MODEL
  • joel garcia Nov 05, 2008
    my z5426 keeps oving on one side even when its on neutral
  • Anonymous Mar 16, 2014
    how to change transaxle belt
  • Anonymous Mar 25, 2014
    My belt broke just need to replace it
I would like a pic the belt so icould see how strech it
Posted on Jun 14, 2010
  • 18 Answers
There is no adjustment..it is set by the spring that engages ur drive belt....
Posted on Sep 03, 2008
Why burning belt on 48" Craftsman riding mower
Since you mentioned "48-inch riding mower" let's assume your question is about the mower deck and not the overall mower or its main drive belt (if manual shift-on-the-fly model). If the belt burns that means it is running but slipping against something; or that the drive sheave us turning against an impeded belt. In the first case the belt will be burned along its length; in the second the burning will be occuring in one location(s) along the belt. In any case of belt slippage, check first that all tensioners (springs) are properly in place and not broken or fatigued and in need of replacement. The only other thing would be resistance to belt running, such as:
blade blockage; blade rotor resistance from lack of grease or ruined bearing in need of replacment; grass clogging on deck underside or under blade drive pulley on deck top side; a pully sheave out of round; an obstacle between belt and sheave that is preventing free turn of sheave and belt run; misrouted belt; an overstretched belt that cannot be sufficiently tensioned. Inspect and correct or replace as needed.
Aug 19, 2014 | Craftsman Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Craftsman 42 '' 19.5hp lawn tractor gear shift will not engage. Engine and blades work fine but cannot put tractor in gear.
the belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Jul 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How do you route the motion belt
Go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model number that is under seat. Should start with 917. Then scroll down to Ground Drive and there's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
1,850 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
