Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer ultimate 11
The cold water slowly continues to run into bowl when the spin cycle is engaged how do i stop this
    Genius:
  • 1,028 Answers
Probably bad fill valve ..if water continues to run in when machine is off valve may not be shutting off completely due to trash if screen in cold inlet has been removed to clean and not reinstalled trash can enter valve and prevent complete shut off ..remove 2 screwson back of console pull console forward and roll back pop 2 clips 1 each corner remove lid switch plug cabinet will lean forward and off to acess valve
Posted on Sep 02, 2008
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
Sep 26, 2012 | Washing Machines
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
